Merge and edge
All  1-4  5-6
1041.5 In reply to 1041.4
>>Any other ideas for what a Merge command should do?
Until now I haven't found out anything so I rely on you to think of something :)
>>The only other problem I'm worried about is that Merge sounds kind of similar to Join [...]
>>I might want to kind of stash it a little bit away in that "advanced edit tools" menu or something extra.
I agree with you about that.
On Rhino newsgroup there was quite a lot of questions like "What is the difference between MERGE and JOIN?", so yes, it might be a problem. Moreover, Merge command even occurs in MoI - Boolean-Merge.
Petr
ps: I have noticed when I click a Show Pts command without pre-selection an object, no command prompt appears...
EDITED: 18 Oct 2007 by TYGLIK
1041.6 In reply to 1041.5
Hi Petr, I have made a note to fix this up for V2. At the moment I'm trying to avoid making any changes that would cause additional translation work.
Show messages: All  1-4  5-6
