Hi Zooen,
> So, this is what I do. But currently there is only the snap "on" not "Point" for the function "add pt" to
> a curve. Well that is enough for me by zooming a little, the precision of the location is sufficient.
Use "add pt" on the control polygon (with control points turned on), then drag the new point over to the point marker so you can snap on to it.
> I will take this opportunity to ask another question. Is there a possibility or a trick to extend an arc-shaped
> curve while maintaining its overall shape?
Replace your arc-shaped curve with an exact arc (use Draw curve > Arc > 3pts) and then the Edit > Extend command will do an arc extension rather than a straight line extension.
You could also draw in your own custom extension using Draw curve > Freeform > Control points, make sure you have "straight snap" enabled and place the first 2 points of the new curve along the tangent line.
