Need help with a script handler for interactiveViewChange('zoomarea')
Hi Michael -
I need help using interactiveViewChange('zoomarea') within a script.
I have tried various event handlers inside my ZmArea() function to proceed after interactiveViewChange('zoomarea') is finished.
The only way I have found that allows interactiveViewChange('zoomarea') to finish is to add a "Continue" button that allows the script to progress when clicked.
I'd like to not use a Continue button and have the script to proceed automatically when the user releases the mouse after drawing the zoom rectangle. Is that possible?
<html xmlns:moi>
	<head>
		<link rel="stylesheet" href="moi://ui/moi.css" type="text/css">
<script>
  // _TestZoomArea.htm
  moi.ui.mainWindow.viewpanel.mode = '3D';
function Main()
moi.ui.alert( 'Do main stuff here - then Zoom Area' ) ;
// do main stuff
// Zoom Area
ZmArea();
moi.ui.alert( 'Finish doing more main stuff here' ) ;
// more main stuff
function ZmArea()
	moi.ui.mainWindow.viewpanel.getViewport('3D').interactiveViewChange('zoomarea');
	    while (1)
			moi.ui.commandDialog.waitForEvent();
			if ( moi.ui.commandDialog.event === 'continue' ) {
               return;
</script>
</head>
	<body class="commandbody">
		<div style="text-align:center; font-weight:bold;">
			Test Zoom Area
		</div>
		<div class="commandoptions">
			<table style="width:100%" cellspacing="0" cellpadding="0">
				<tr>
					<td><moi:PushButton class="SlimBtn" id="startbutton" onbuttonclick="Main();">Start Test</moi:PushButton></td>
					<td><moi:PushButton class="SlimBtn" id="continue" >Continue</moi:PushButton></td>
				</tr>
			</table>
		</div>
	</body>
</html>
// _TestZoomArea.js
function DoZoomArea()
    var dlg = moi.ui.commandDialog;
	while ( 1 )
		// Wait for user input
		if ( !dlg.waitForEvent() ) // if waitForEvent returns false the command is being canceled.
			return false;
		if ( dlg.event == 'quit' ) // User Quit
			break;
	if ( moi.ui.commandDialog.event == 'cancel' ) {  // User Canceled
            moi.ui.commandUI.cancel();
            return;
DoZoomArea();
10403.2 In reply to 10403.1
Hi Ed, unfortunately I don't think it is possible currently for a script to use interactiveViewChange() in this way.
The way view.interactiveViewChange() works currently is that it posts a message and then lets the current call stack unwind and doesn't start the view change loop until when the message is processed.
I will add in an optional 2nd parameter to interactiveViewChange() to make it go into its modal loop immediately rather than posting a message, so in v5 you will be able to do it like this without setting up your own event loop:
moi.ui.mainWindow.viewpanel.getViewport('3D').interactiveViewChange('zoomarea', true);
10403.3 In reply to 10403.2
Thanks Michael - I'll use the Continue button for now.
Looking forward to Ver 5.
10403.4 In reply to 10403.3
Hi Ed,
Checking moi.majorVersionNumber might be helpful?
    if ( moi.majorVersionNumber < 5) {
	while (1)
                return;
    } else
--Larry
10403.5 In reply to 10403.4
Good idea Larry - We'll do.
