Hi Barney, if you place the attached file in the MoI appdata startup folder, that should make the default value of the "Maintain proportions" checkbox in the edit size menu to be off.
You can find the appdata folder where the moi.ini file is located, to see the location go to Options > General > "Edit .ini file" and it will show the path on the dialog box that pops up.
Inside the appdata folder is a sub-folder named "startup". Place the attached .js file there and then Moi v4 will find it and run the script in it when it starts up.
