Newbie MOI to Renderer Q
All  1-2  3-7
1040.3 In reply to 1040.1
Angeliclight,
I'm in the same place as you. See my post # 1034.1 titled "MoI with HyperShot Renderer"
It doesn't get any easier than this. However, it's not free (except for 15 day trial demo).
MoI $200 + HyperShot $200 = $400 US
I'm a business owner and the time savings from both these programs is huge.
Ed
1040.4 In reply to 1040.1
Hi angeliclight, yes the problem tends to be that many programs don't just render, they also have modeling and animation functions as well so that tends to make them rather complex.
I agree with Ed that HyperShot seems to be the all-around easiest to use of anything that I have seen - it's focused just on rendering and nothing else. One of the best things about it is that it does lighting from a pre-defined environment image capture, this makes it easy to get very nice lighting without messing around with setting up all your lights yourself, that tends to be one of the most difficult steps normally.
Pilou also gives you several ideas above, I'd say probably check out http://www.kerkythea.net/ .
There is also another thread here with some discussion: http://moi3d.com/forum/index.php?webtag=MOI&msg=651.1
1040.5 In reply to 1040.4
You also might check out Carrara 3D Express from http://daz3d.com
1040.6 In reply to 1040.5
yes Carrara has a very good renderer and one of the more easy to use!
1040.7
Carrara render engine is good, it renders GI for interiors fast, but currently there are some problems regarding that. Just read the forums if you want to know more.
Show messages: All  1-2  3-7
