To bend an object
10394.1
Hi guys,
Would you know, please, how to bend a logo with a diameter of 150 cm to get true 3D dimensions?
The radius of the rounded wall is 112 cm.
mk
Size: 333.7 KB, Downloaded: 73 times, Dimensions: 2152x1345px
10394.2 In reply to 10394.1
Nevertheless, the Rhino trial Bend gives me the best results.
Size: 353 KB, Downloaded: 48 times, Dimensions: 1949x1250px
10394.3 In reply to 10394.2
hi Mk,
the flow tool will work for this application.
Barry
10394.4 In reply to 10394.3
Wow! Wow! Wow!
Thank you Barry.
One more reason to love MoI!
Cheers,
mk
10394.5
You can even use curves for a bend, in stead of surfaces.
─ Metin
visualizer • illustrator • 3D designer — metinseven.nl
Size: 328.3 KB, Downloaded: 21 times, Dimensions: 1096x1065px
10394.6
Here's a visual curve flow example:
After performing a flow, select the resulting object and enable the History to interactively adjust the Flow result.
─ Metin
10394.7 In reply to 10394.6
That's right, thanks Metin!
But you need to position carefully the projected curve.
BTW
Where is that History enabling thing?
Size: 557.3 KB, Downloaded: 41 times, Dimensions: 1713x1313px
10394.8 In reply to 10394.7
Hi Marky,
You can activate the History here:
─ Metin
10394.9 In reply to 10394.8
Hi Metin,
Thank you.
What else, in front of my nose!
M
example of history with Flow! ;)
