Save image with file
10390.1
I know this has been discussed before - I used to have a script that automatically saved an image file (.jpg or .png - I cant remember which) in the same folder as the Moi3d file - and updated it as the file was saved.
Anyone know what that might be?
Cheers in advance :)
10390.2
BTW I'm using Moi v3 ;)
10390.3 In reply to 10390.1
CaptureScreenToFile – you can use this script to save a screenshot out to an image file by using a shortcut key, without needing to run any other program.
Alt+S script:var img = moi.view.screenshot( 'viewpanel', false ); var name = img.getSaveFileName(); if ( name != '' ) img.save( name );
10390.4 In reply to 10390.3
Thanks for that ;)
This is the one that just automatically saves an image file & updates it as you save the model, right?
If you want to save your model AND the image in the same time, you could add this line in the save.js and the saveas.js script files.
10390.6 In reply to 10390.5
You mean this one?
Yes
Add this line to your two scripts save.js and saveas.js
