I am seeking some input, from the user community to see if MOI is the tool for me?
See attachment below.
So at the top you can see where I designed the 3D portion of this project, to be 3D printed.
In the middle, I created the enclosure in a 2D vector application for laser cutting.
At the bottom you can see the final assembly, for my custom Atari 2600 cartridge.
The problem is I had to build the 3D and 2D sections in different applications.. this is a pain when trying to get things to
align perfectly and fit properly. I am wanting to be able to build my entire solution in one tool, but be able to easily, export portions as 3D printable files, and other portions as 2D files for laser cutting. I am also hoping the program has a built in tool, to easily add finger grooves, and the ability to compensate for kerf/material thickness etc.
Is this workflow something MOI can offer to me, and improve my development time, using a single tool?
thanks for any input
Sam
I have downloaded the trial, and tinkering with it, but have not got a good handle on it all yet, so figured I would as more experienced users.
PS (I know the laser cut file doesn't show the screw holes, I forgot to unhide that layer when I took the screen shot, but you get the point)
