OK, so your reasoning is that because it is complicated it won't happen in MoI?
Alibre Design has no problem with it - see screenshot. Because Alibre Design is parametric it's less of an issue there than in MoI because I could just swap the order of operations around. With MoI not being parametric (understandable) it becomes more important IMO for the application to do what the user expects as it may be very difficult to undo multiple steps and change the order of things (e.g. shell before fillet).
An added complexity for MoI is that it forces the user to consider the order of things depending on the values used, for example:
Wall thickness = 3mm, fillet = 5mm : do fillet then shell
Wall thickness = 6mm, fillet = 5mm : do shell then fillet
Andy
