Construction line script
 1-13  14-33  34-48
1029.34 In reply to 1029.33
Hi Guy,
> BTW :
> could you give us a short explanations on how to use this ConstructionLine script v3 ?
While the ConstructionLine command is running you can create construction lines inside of a viewport by the usual method of pressing and holding the mouse down and dragging the mouse with the button still held down, but the difference from regular construction lines is that these ones will persist after that command exits.
Note though that if you just want to use a construction line as a helper during drawing you do not need to use this script to add one, you can create a construction line inside of any drawing command or anytime that MoI is asking you to pick a point input. To place a point you do a mouse click - if instead of clicking you hold down the mouse button and drag it away you will create a construction line at that time, the only thing the special script does is make lines that stick around for longer than the current command, normally construction lines are cleared when the current command exits.
> Is it the last (best) version of your Construction Line script ?
Yup, I think it is the latest - it's actually not my script it was created by someone else.
> Is this version do all what the previous did ?
I believe so, yes.
1029.35 In reply to 1029.34
So where is this last version in definitive?
1029.36 In reply to 1029.35
I guess the last one that was attached in this thread which looks like here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=1029.25
1029.37 In reply to 1029.36
Hello Guy
I have made a tuto in French for input an icon inside UI ;)
http://moiscript.weebly.com/ajouter-une-icocircne.html
Tout reste valable et pour l'installation de la nouvelle "CLine"
voici la ligne qu'il faut mettre entre les 2 td entre crochets en attente ;)
<moi:CommandButton icon="icons/CLIcon.png" command="ConstructionLine"><moi:Text textid="CLine"></moi:CommandButton>
et non le texte d'aide fourni (ça ne marche pas pour moi :)
A quoi il faut ajoute pour la version Française dans le fichier FrenchStrings.txt
CLine=Ligne par exemple
On obtient à la fin, la dernière icône en bas à droite :) les couleurs de l'interface sont juste inversées avec un programme 2D pour l'image jointe!
j'attends la V3 pour faire tout cela automatiquement :)
EDITED: 4 Jul 2012 by PILOU
1029.38
Thank you very much Michael and Pilou,
@Pilou : yes and thanks for your efforts, but I prefer the simplicity just using a letter as a shortkey and the name of the script as the commande line without anything else more.
For now it seems to be the easier and quickest way for me.
Best Regards,
Guy
_____________________________________________________________________________________
always working on few funny projects : www.nauticaerium.com ; www.conceptarum.com and so on...
1029.39
French version of "Construction line script" is done ! :)
1029.40 In reply to 1029.39
I have a little memory hole! :)
What is this Construction Line ?
Does it different than the Helper Line ?
Edit : Ok My memory is coming back! :)
@ Bear : before translate something take a look on my site if maybe I have yet made this! :)
I am now translating Section Divers & Scripts so your above one is cool for me! :)
EDITED: 26 Feb 2016 by PILOU
1029.41 In reply to 1029.40
Maybe it is not different from "Helper Line". I don't know.
I found this script by clicking here :
Edit : Before translating , I took a look at your website to see if maybe you had already done that! :)
(There is a lot of information on your site! )
EDITED: 26 Feb 2016 by BEAR17
1029.42 In reply to 1029.41
Section Divers Done! :)
http://moiscript.weebly.com/liste-scripts-commandes.html
J'attaque la section Scripts! :)
In fact Constructions Line is exactly like Helpers Lines except the fact they stay living !
And die when you want!
Section Scripts Done!
Big Section Maths for tomorrow, but many commands are yet translated on my site
so just move the files for update this crazzy Icons' list on the Task bar! :)
Bravo to Marco!
1029.44 In reply to 1029.43
I can help you Pilou , if you want.
Bear
1029.45 In reply to 1029.44
ALL is done! ;)
1029.46
Is is somehow possible to change colour of construction lines?
Cheers,
Dejan
1029.47 In reply to 1029.46
Hi Dejan,
Yes, you can set the color in moi.ini, go to Options > General > "Edit .ini file" button, and then inside moi.ini find the [Drawing Aids] section and there's an entry in there for "StraightSnapLineColor" like this:
[Drawing Aids]
StraightSnapLineColor=103,0,0,0
That takes 4 comma-separated values which are for Opacity,Red,Green,Blue - the values can range from 0 to 255.
That controls the color for both construction lines as well as the straight snap lines that show when straight snap is engaged.
1029.48 In reply to 1029.47
Thank you Michael! Your support here is absolutely amazing :-)
Cheers,
Dejan
Show messages:  1-13  14-33  34-48
