"Pipe2 Thickness"
Seems this command has some glitches ? (V3 & V4)
Pipe & Pipe 2 works fine...
10282.2 In reply to 10282.1
Hi Pilou, can you please post a link to the command or attach the command that is not working for you here?
10282.3 In reply to 10282.2
Maybe it's the same than Pipe2 ?
But I have it in my folder commands...
10282.5 In reply to 10282.4
Hi PIlou, what is the problem with it that you're seeing? It seems to be working ok for me over here:
10282.6 In reply to 10282.5
I have this even numbers i input!
Edit: that works with your 4 & 1 ! (or 5 & 2)
So seems there is an error when diameters & thickness are not compatible!
EDITED: 21 Apr 2021 by PILOU
10282.7 In reply to 10282.6
Hi Pilou, you've entered in invalid options there.
You're specifying an outer diameter of 5:
That means your thickness value needs to be less than 2.5 :
10282.8 In reply to 10282.7
Yes seems that.... :)
So maybe an alert message will be more friendly! :)
