selecting
All  1-2  3-6
1028.3 In reply to 1028.1
Hi Val,
Like Pilou mentioned, Esc for unselect (also turns off points).
For selecting all curve objects, you can make a keyboard shortcut with this as the command:
script:moi.geometryDatabase.getObjects().getCurves().setProperty( 'selected', true );
> *shortcut for reselect
Could you explain some more about what this one would do?
If you make a mistake when selecting things, you can use undo to go back to the previous selection, is that it?
1028.4 In reply to 1028.3
Hi Michael, and Frenchy
thanks for the replies, and thanks for the shorcut.
by reselect I meant, to reselect previously selected curve/object. Sometimes using a tool it will unselect the object or curve after operation.
also, is it possible to change esc to like "a" I don't see it in the shortcut menu.
thanks!
1028.5 In reply to 1028.4
Hi Val,
No sorry there isn't any way to do this. If you let me know which operation is causing you problems I might be able to tune it up. But some operations are geared towards selecting the output so you can do something with it.
There isn't any way to change Esc, but you can hook up another key to do deselection in addition to Esc, set this command on the shorcut key:
script:moi.geometryDatabase.deselectAll();
1028.6 In reply to 1028.5
thanks Michael
Show messages: All  1-2  3-6
