scaling part of the object
10268.1
Hello,
I need to scale part of the object, where I have the dimensions.
I need to expand the object from 60 to 80 in the front part, without change the back of the object.
I tried the 1D scale, but it stretches the other part as well.
I tried to select some faces and move, no success.
Maybe cutting the object in half?
Tks.
Ulisses
10268.2 In reply to 10268.1
Yes cut !
Or Separate all (but that will maybe break some things maybe important when you Boolean Union again )
"Show points" select and move them...
10268.3 In reply to 10268.1
Hi ulisses,
Almost, I'd probably try cutting the object into 3 pieces. Draw in 2 cutting lines in the top view and use them as the cutting objects in boolean difference to cut your object into 3 separate pieces.
Move the left piece over to the end location you need, and then use Scale1d to stretch the middle part out to meet it.
If you need a demo please post your .3dm model file or e-mail it to me at moi@moi3d.com if you want to keep it private.
10268.4
Thank you Michael, Pilou,.
I didn't know I could use boolean dif with a simple line, great.
I cut in 3 parts and extended the middle one, then boolean union.
Looks like it is ok.
Great!
When I've seen this request I imagined not a double cut but another process.
1/ single cut with a line boolean difference
2/ moving a part at the right place
3/ lofting between the 2 parts
What do you think about it ?
Right or wrong idea ?
P.
10268.6 In reply to 10268.5
Hi Phiro,
It's fine, it's just that if there are a lot of edges to loft between that would probably take a little more time to do that than the 3 part method.
The 3 parts way needs just one stretch using the edit frame like this:
You're right Michael,
I forgot a mouse scaling and though only a numpad dimension scaling which was less easy.
Multiple ways, for same goal...
