3d view angle
10230.1
quick question: What is the default 3d view angle? I believe it was 27.5 but I don't want to restore all the defaults and I've changed so many things I can't remember the default for the view angle. Also, why was the default 3d view angle chosen? Thank you
10230.2 In reply to 10230.1
Hi beanworks, yes that's correct the default field of view angle for a perspective view is 27.5 degrees.
That value was chosen because it corresponds with the field of view given by a 35mm film camera with a 50mm lens which used to be a common set up in photography.
10230.3 In reply to 10230.2
awesome, thank you!
