Hide unhide
10220.1
It's me again . Is there a srcript or a manipulation to recall only the last hidden objects.
-Zooen
10220.2 In reply to 10220.1
Hi Zooen,
I don't have a script that does that exactly, but you might find this Hide/Show script helpful as it gives some better control over selecting which hidden objects to be shown. I have it bound to CTRL+H and use it all the time:
script: /* hide selected objects, or show subset if no selection */ var gd = moi.geometryDatabase; if ( gd.getSelectedObjects().length != 0 ) { gd.hide(); } else { gd.showSubset(); }
I got it from the Forum, I think it was from Michael, but I don't find the thread discussing it.
--Larry
10220.4 In reply to 10220.1
I think I had asked this question, too, and the answer was negative.
10220.5 In reply to 10220.1
Hi Zooen,
You can do that with Undo if it's the first thing you do after the hide.
If you want to return to a specific hide/show state after doing some work, you can do that using the "Isolate" function. That's triggered by doing a right click on the Edit > Hide button instead of a left click.
Isolate will hide everything else other than what is selected, leaving just the selected objects visible. It will also retain a memory of each object's hide/show state before the Isolate was done and restore it when trigger it a second time.
If you repeatedly need to hide/show the same objects, then it's time to assign them a name or a style and use the scene browser.
10220.6
Thank you all for your comments and advice,
I will work on this subject to improve my practice.
-Zooen
