Import object .obj
10184.1
I can't import objects in .obj format anymore, either from Blender to MoI or by "import obj".
I have this error message:
Thank you in advance for your help
_Zooen
EDITED: 28 Sep 2021 by ZOOEN
10184.2 In reply to 10184.1
Hi _Zooen, can you please post the import obj script that you're using so I can try it over here?
for Moi try this one by Max Smirnov
Better if faces are "quadrangulized" ;)
http://moi.maxsm.net/files/scripts/ImportObj.v.1.5.2015.09.10.zip
10184.4 In reply to 10184.2
Sorry for the inconvenience Michael !
The file I was trying to import was very "heavy" and / or corrupted. I redid the manipulation with a previous lighter version and everything works correctly.
MoI3D-V4.0 - Blender 2.83 - MHC 1.2 - SU Pro 2020
Zooen
EDITED: 22 Feb 2021 by ZOOEN
10184.5 In reply to 10184.4
No problem Zooen, I'm glad you got it working ok now.
150 000 polys is a reasonnable maxi ;)
10184.7 In reply to 10184.6
>150 000 polys maxi
Where can we find this property in MoI3D ?
- Zooen
10184.8 In reply to 10184.7
I am not sure that you can find this info directly in Moi3D before the import ...
maybe use something like that https://www.meshlab.net
You can find this info at the Export OBJ from moi ;)
After the import : native button Detail (faces)
About the size number itself : it's the practice :)
Of course it's depending of your config...
Generally the native SubD : Create From File is a little more long that the _import OBJ by Max Smirnov
EDITED: 23 Feb 2021 by PILOU
