Splines from MoI to C4d
10172.1
Hi, how can I bring splines form MoI to c4d in order to make a sweep there?
I tried the dxf in different options...the polylines which in cinema arrive are disks instead of circles...
10172.2 In reply to 10172.1
I am sure that you can export in OBJ format then import OBJ in C4D... but not this format for only curves...Surface yes...
by MacGreggor (who has a big Gallery here https://moi3d.com/gallery/viewitem.php?id=1092
Moi
C4D
Modelisation MOI 3D + C4D By Mac Greggor
EDITED: 17 Feb 2021 by PILOU
10172.3 In reply to 10172.1
Hi Mala, if you have 2D curves I think you can use .ai format, otherwise I'm not sure that there is a way for Cinema4D to import curves.
You might try this plugin: http://www.rhino.io/
You also might want to ask Cinema4D support.
10172.4
perhaps with a spline generator...but which formats...hmmm´....
10172.5 In reply to 10172.3
i got not Rhino
I will ask to MacGreggor! :)
So wait & See...
EDITED: 18 Feb 2021 by PILOU
10172.7 In reply to 10172.5
Hi Mala, the .3dm file format that MoI writes is also the Rhino file format. So if the plugin I linked to above can import curves from Rhino to Cinema4D it may also be able to do the same for .3dm files saved out from MoI as well. I'm not sure but it is worth a try.
I don't think it will work for transferring surfaces and solids because it uses display meshes which MoI does not write to .3dm files, but for curves it might work ok.
10172.8 In reply to 10172.4
Hi Lara,
For me it works best this way :
If the curves are in one plane (2d curves) I prefer to export them in *.ai format.
If the curves are 3d curves then I go for the *.dxf format.
Choose > polylines from rhe menu. And make sure that your curves are not closed,
they should have two open ends. If you have closed curves, just trim them tp get two
open ends.
10172.9
Hi Tom, I just wanted to post my workflow that was successful...it´s the same like yours. The only difference is that my closed circles arrive cineama with no problems. Thanks...
You can also export artificial surfaces in obj format and kill the internal surfaces in C4D so you obtain only curves 2D/ 3D! :)
10172.11 In reply to 10172.10
good idea. next project. thanks pilou!
Sorry i can't test i have not C4D!
Answer of MacGreggor ;)
the requested format is DXF, with the option Polylines otherwise we have nothing at all in C4D.
The default angle of 1 generates very close points, we can increase this value to 10 for example.
Then in C4D, we get a linear spline, perfectionists fond of precision can use Respline : but 60
https://www.alphapixel.net/respline-c4d/ (scroll)
MacGreggor
So Take Export DXF / Export Type: 3D Curves / PolyLines / Angle 10 :)
Et voila!
By MacGreggor
Modelisation Moi Render VRay
