Thanks for explanation.
I think i found an issue about the Moi's PDF file export.
The layers (like styles) are present when opened in Adobe Acrobat Reader, but not present (the same file, in my tests) in Adobe Illustrator (CS6 to CC2021), which i use to edit the file, if need.
I will use only the DXF file. For me its a slower workflow, have to import to Illustrator, correct the artboard size (is always to small), edit the colors styles/layers (all wrong, some times ilegible) and export it as a PDF file, instead of sending the PDF file right way to clients and/or suppliers.
Anyway, thank you for this wonderful software.
Best regards
Carlos
