how to bridge two cylinder like this
10138.1
I tried "blend" , the result is not I expect.
EDITED: 5 Feb 2021 by JACKLEEINST
10138.2 In reply to 10138.1
Hi Jack, this area here will probably be pretty difficult to model with CAD:
I guess probably what I would do there would be to make a blocky version and then take it into a displacement brush program like 3D Coat or ZBrush and then use those sculpting tools to shape that area.
10138.3 In reply to 10138.2
thx
10138.4
Hi Jack :)
If you want kind of transitions between two cylinders higlighted by Michael you can use Max SubD tools we have
Concept:
Stages
Result subdivided
You can set and mantain an exact diameter for cylinders,just transitions will be approx
Final object is a solid,so you can do booleans etc.
If you want to change the shape of transition just play with "polys" moving them until you get your target
If you are new here read this thread about SubD
http://moi3d.com/forum/index.php?webtag=MOI&msg=9689.1
file attached with all steps
M
EDITED: 19 Dec 2021 by M-DYNAMICS
10138.5 In reply to 10138.4
Excellent demo of SubDivision in Nurbs package! ;)
I recall the few tools but sufficient ...
sSudDiv
sSPlit, SBridge, sSCale
Extrude
EDITED: 5 Feb 2021 by PILOU
10138.6 In reply to 10138.4
awesome!!! thx very much.
10138.7 In reply to 10138.6
Great M ! but not easy...
10138.8
Tried to do this but the object broke ... not solid: \
mb if you do not rush and do everything carefully - it will work out, but time is more expensive.
In fact not so difficult ! :)
But it's eyes touch! :)
https://moiscript.weebly.com/uploads/3/9/3/8/3938813/gog.3dm
EDITED: 6 Feb 2021 by PILOU
10138.10 In reply to 10138.9
wow! amazing!!
