To much Icons in the Commandbar
10135.1
i installed the Custom-UI with the „big“ commandbar. It's great on my 4K Display. But on Displays with smaller Resolution the lower Commandbar is to long. Now i just want to resize the UI. But for that I have to go to the Preferences. The button for this is on the right end i can't see.
Is there a shortcut for opening the prefs?
And how can i delete elements in the commendbar (for example the four squares numbered from 1 to 4)?
Best regards Wolfgang
10135.2 In reply to 10135.1
Hi wsiew.
To get to the settings under this panel there is an elevator, pull it to the left, the necessary buttons will crawl;).
Delete or create a new folder there and move the file " 55 CamSwitch.js "
The way there C:\Users\...\AppData\Roaming\Moi\startup\.
10135.3 In reply to 10135.1
Hi wsiew, for the CustomUI v2.0 beta, the one that works with MoI v4, each button is generated by a separate .js file in your MoI appdata startup folder.
So to remove some buttons you would remove some of the .js files.
On Mac the MoI appdata dir is in ~/Library/Application Support/Moi . By default the OS hides the Library folder, so to go there use the "Go to folder" menu item on the "Go" menu in finder and put in ~/Library/Application Support/Moi .
Then inside there go into the startup folder, that's where there will be a .js file for each button you're seeing. Move the ones you don't want somewhere else, they can go into a sub-folder underneath startup, only the ones directly inside the startup folder will be processed.
There is a scroll bar on the bottom you can use to scroll over to it.
You can set up a shortcut key for opening the Options dialog by putting this in as the command part of a shortcut key:
script: /* Open Options dialog */ moi.ui.createDialog( 'Options.htm', 'resizeable,defaultWidth:43em,defaultHeight:32em' );
