Bumpy grip
10131.1
Hello, I need an area on my ring geometry that is slip-resistant. I want to achieve this through two things. Once a fold, as I have already described and implemented here.
But then also through a rough surface. Similar to the one in the photo.
Do you have an idea for the implementation? Tomorrow I will talk to the mold maker whether it is enough to determine the sequence and he will then program the machine there for rough ...
EDITED: 10 Feb 2021 by MALA
10131.2 In reply to 10131.1
Google "Texturing molds for thermoplastics: factors for success" at Moldmakingtechnology.com.
The metal mold, (steel? / aluminum?), is etched with ferris chloride, or nitric acid, or ?.
Residual EDM sutface?
Smooth areas are masked off.
-Brian
A seven sided polygon?
I believe that you have just to make some works' color to your object!
Say Blue for the rough surface, other color(s) for all special surfaces...
and then your 3D Print (?) will follow these colors for each different material you want...
10131.4 In reply to 10131.1
If it was a 3D printed part, Cura slicer has a fuzzy skin option for a rough surface on parts.
https://www.youtube.com/watch?v=gh5wC4Ti95s @3:30 timestamp
10131.5 In reply to 10131.1
Hi Mala, yes it would be best to discuss this with the mold maker, it's not very feasible to try and directly model that type of bumpy surface in a CAD program.
