First project + Renders
101.1
HI !
Simply small project.
Build with MoI (beta 4.09.2006)
Render: 3dMax - PowerNurbs(3dm-import) - Maxwell
3D View
And just for fun :)
Some wishes:
1. !!!!! Export IGES !!!!! please
2. Project curve to surface
3. Leyers
4. Separately "Select only curves", "Select only surfaces", points etc.
5. Variable Fillet
6. Extend curve
7. Analyze surfaces (like Rhino`s Zebra, Show and Join naked edges)
My impressions - very interesting program, is intuitively clear.
Best regards!
Little.
PS Sorry for my english
101.2 In reply to 101.1
Astonished :)
2 . For the moment can be be emulate by extrude a curve toward an object + Trim + Boolean
6 . Extend curve exist :) (near Trim)
EDITED: 12 Sep 2006 by PILOU
101.3 In reply to 101.2
Frenchy Pilou
1. It is a little not that. It would be much easier to have a command "Project to Surface"
2. I have written not precisely. It would be desirable more parameters, such as "Extend by Arc", "Extend Smooth". Or it is even better - "Adjustable curve blend"
101.4 In reply to 101.3
Sure but Michael can't make all in a same time :)
Untill this we must make some tricks :D
101.5
Nice work.
I have wondered how Power Nurbs would import MoI files to Max.
Very well it seems?
101.6 In reply to 101.5
With this model PowerNurbs has worked very well.
I used 3dMax 8 SP3 and PowerNurbs Tools v1.62
Screenshot here...
http://img146.imageshack.us/img146/8145/snap1eu9.jpg
101.7 In reply to 101.1
This looks awesome. How much time did you need for the Remote?
Michael H.
101.8 In reply to 101.1
Very nice renders!!!
I'm afraid that it's going to be a little while for most of your requests, except IGES export should be coming soon and I should be able to to a project curve in not too long.
For extend by arc, try Draw curve / Arc / Cont (continue) - this lets you draw an arc that is tangent off the end of an existing curve.
101.9
2 Michael (MMHS)
Several days. This is not composite model. In essence I used Boolean and Loft/Sweep.
Difficulties were only in the center section of the remote - with the buttons. There it was necessary to construct many additional surfaces, that to use Trim and Boolean.
2 Michael Gibson
Thanks for your help!
I will try.
And final composition especially for you :)
101.10 In reply to 101.9
Very nice!
