MOI3D v 4.0 decimal separator
10093.1
Hello,
I'm running MoI v. 4 on Macosx 10.15.7, with the comma as decimal separator.
I've noticed that when you create an object (eg. a line), you must use the period as decimal separator and the comma as coordinate separator. For instance,
1.2,4.5
...instead of the comma and, say, the semicolon, respectively, e.g.
1,2;4,5
Perhaps a future version of MoI could let users customize separators.
Cheers,
pr1
10093.2 In reply to 10093.1
Hi pr1, if you are using the comma as the decimal separator MoI will be expecting you to have a space between the coordinate values.
So for example when drawing a line to place a point at x = 5,2    y = 10,3 you should put in:
5,2 10,3
10093.3 In reply to 10093.1
hi.
you could also use space as the coordinate separator
http://moi3d.com/4.0/docs/moi_command_reference1.htm#__XYZ%20/%20Distance%20/%20Angle
1,2 4,5
best,
marco
10093.4
Hi Michael and Marco,
Thanks for your feedback.
Apparently, both periods and commas work as decimal separators, as long as you use spaces as coordinate separators:
5.2 3.4
or
5,2 3,4
That's cool.
Cheers,
pr1
