Is it possible to check curvature type between surfaces?
10086.1
Is there any secret command in MoI3d to determine what type of curvature is between surfaces: G0,G1,G2,G3? Is it possible to see that in MoI someday? Is there command for similar things in curves?
I have Rhino 6 but similar command is in Rhino 7. I wonder that maybe MoI has or will have similar thing.
10086.2 In reply to 10086.1
Hi mdesign, sorry no there currently isn't any checker for curves or surfaces like that in MoI. I do want to work on analysis tools in MoI in the future though.
10086.3 In reply to 10086.2
Thanks Michael for your answer. I would love to see surface and curve analysis tools in future MoI. After killing VSR plugin there is only one to one surface analyze in Rhino 7. There is no possibility to check matching surfaces on multiple surfaces at one time.
I`ve found that after buying Rhino I use MoI more often. I love to use those both software together lately (mainly for 3d printing).
I`ve found also that I prefer speed of MoI GUI and amazing snapping tools (more easy to predict without many clicks). For now I use Rhino for fixing stuff, for matching surface command, for xnurbs plugin and for some useful commands too. I start mostly in MoI and I move to Rhino when I need something specific. I`m glad also that you created way to use MoI with Rhino 7.
Thanks for that.
You have this for curves analysis ;)
http://moi3d.com/forum/index.php?webtag=MOI&msg=6634.1
10086.5 In reply to 10086.4
Thanks. For curvature graph I use Rhino. I`m looking for fast way to check continuity between surfaces. What is not possible at Rhino 6. In Rhino 7 its possible only one pair at time. Old Autodesk VSR plugin allowed to check multiple edges between surfaces at one time but it works only with Rhino 5. VSR plugins was killed before v6. For now if I will update from Rhino 6 to Rhino 7 it will be mainly for this command: EdgeContinuity https://docs.mcneel.com/rhino/7/help/en-us/commands/edgecontinuity.htm . I hoped that I will find solution like that in MoI or as external paid script or so. This EdgeContinuity command is also very limited because of checking only one pair at time. It would be nice what continuity type is present on each edge of a whole object.
10086.6
Check this rhino's plugin.
"Global Edge Continuity" analysis tool for quickly analysing surface continuity between multiple surfaces at once.
I found this recently on youtube, this guy (Andrew Jackson) mainly uses solidworks but uses rhino for analysis.
https://www.youtube.com/watch?v=4FceX93m7T8&t=23s
10086.7 In reply to 10086.6
Hi Ko, sorry no there currently isn't a tool in Moi for doing that. I would recommend using Rhino for that analysis.
10086.8 In reply to 10086.6
10086.9
Also FreeCAD have a tool for Zebra map shading, under Workbench Curve. is free opensource tool multi-platform.
Y-zebra-checkt
Corner-zebra-checkt
Greetings
Else... ;)
You have also the free Polycad who has Zebra and other stuffs! :)
Moi <---> PolyCad with IGES
https://www.polycad.co.uk
EDITED: 14 Oct 2022 by PILOU
10086.12 In reply to 10086.11
PolyCAD don't support trimmed surfaces!
10086.13 In reply to 10086.12
'Zebra Stripe': {
lightingStyle : 'CustomLevels',
specularHighlights : true,
specularBrightness : 100.0,
specularFocusSize : 0.0,
metallicLighting : true,
fixedLightPositions : false,
customKeyLightLevel : 0.6,
customFillLightLevel : -0.5
Zebra striping and others only give a visual indicator of continuity. No information about the type of curvature that exists…
Just a note.
