Hi SalomonD, that looks like probably a rough angle set for the display mesh.
Take a look under Options > View > Meshing parameters > "Mesh angle". If that is set to a rough angle value it will make a rough mesh. The default is 10 degrees, if you set "Mesh angle" to 10 and also check "Add detail to inflections" does that solve it?
