AutoRotate script final
 1-14  15-24
1001.15 In reply to 1001.14
Sorry, I should have said more than one revolution without the slight pause. I am using the AutoRotate2 script.
EDITED: 1 Feb 2013 by ORION20036
1001.16 In reply to 1001.15
I posted a few weeks ago relating to being able to modify the AutoRotate2 script to loop more than one time so I can do a screen video capture. The script does turn indefinitely, but has a slight pause with every revolution. Any information on how to modify the script so I can set the number of continuous revolutions without a pause would be appreciated.
I use animation lab with Turbocad, but like the moi rendered version for a quick visual look around of my model, as it is so simple and also fast, plus great for YouTube.
Any help appreciated.
Thank You!.
1001.17
Paul-
Thanks for posting this, it works great. I'll have to find a decent Mac OS screen capture program so I can use the script and capture quick animations right out of MoI. Very useful!
Michael Cramblet
Packaging Design
Phone: 616-574-6271
1001.18 In reply to 1001.16
It looks like the script currently runs on a "busy loop" where the script is going in a really tight loop kind of continuously churning away. I'll try to modify it to use a timer instead and move more processing over into the main host process. I think that could make for some more consistent motion.
1001.19 In reply to 1001.18
Many thanks Michael, It has great potential for viewing my Cad Sculptures, especially as it is so simple to capture, and your rendering settings are just perfect.
Many thanks for posting the script also Paul!.
1001.20 In reply to 1001.19
Hi Michael, try the attached updated version, this one is kind of "lighter weight" since it doesn't make the script run in a continuous busy loop and that should likely help it have a more consistent motion.
This version will only run on v3 (or v2.5 on the Mac should be ok too).
Hope this helps!
1001.21 In reply to 1001.20
That does the trick just great Michael, I spend so much time on my sculptures that I never have the time to create animations, so this will get me moving on some YouTube promotions.
I will post some of the links later in the week when I have sorted some of my sculptures out to animate.
Many Thanks for your time and innovation!.
1001.22
Hi Michael
Is there a command or script to hide/unhide the background grid
I forget but what is a good screen video capture program
cheers
shayne
1001.23 In reply to 1001.22
Hi shayne, see here for a script you can paste as the command part of a shortcut key for doing a hide/unhide of the grid:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4954.2
I use Camtasia: http://www.techsmith.com/camtasia.html
Show messages:  1-14  15-24
