Newby editing a solid question
All  1-8  9-15
9992.9 In reply to 9992.8
Classy render : )
9992.10
Perhaps a classic error when you loft in your your first try was to have made à caped loft.
You don't see the cap but moi don't know how to join for this case.
9992.11 In reply to 9992.10
<< Don't know how join on this case ...
Boolean Union will work ! ;)
For be clear...if possible :)
9992.13 In reply to 9992.12
Nice thread, is that [glassy render] simlab Frenchy?
I need to test pastic type materials... wondering what polygon setting would
you typically use to then "import" to simlab.
9992.14 In reply to 9992.13
Yep i use only SimLab (because it's very easy and permit to mix many 3D formats in the same time ) in free that is now 1920*800
or even SketchUp format! So no problem of regulate : you can play with smaller etc... if you have complex volume...
example with a model by thegoodguy
I have not made any special regulates (that was just for a test :)
Here SketchUp export from Moi : as you see you are not obliged to use OBJ format :)
A trick : export different objects against all in one if there are several complex objects!
You have another very cool free one (if you had loaded it previous year) : TwinMotion ! Without any limitation!
Updates are free too!
EDITED: 29 Oct 2020 by PILOU
9992.15 In reply to 9992.14
Hi Pilou, thanks for the tips over recent months. You are inspirational.;0)
Merci! Stefano
Show messages: All  1-8  9-15
