Newby editing a solid question
All  1-2  3-15
9992.3 In reply to 9992.1
One way is to copy the oval edges to the desired separation, which become oval curves.
Extrude the oval curves away from each other, without capping ends.
Then hide the curves. Select the new oval edges, and do Blend with minimal bulge ( = 0).
Planar the two Blend ovals and Join the 4 parts.
EDITED: 16 Oct 2020 by BEMFARMER
Will be cool if you can post your 3dm model! ;)
9992.5 In reply to 9992.1
Hi, Viewbyte.
In the video how to do this. There are other ways.
https://yadi.sk/i/HtFLaEBakgF_MA
Extruded Coral, then Blended Coral oval edges .3dm
-B
9992.7
You're all very helpful! Many thanks!
I've got it fixed : )
Sorry I couldn't post the model - very strict NDA...
No problem ;)
Other method (same above for the top top piece)
Trim top box by the Round rectangle for have a round face
Kill the rectangle round curve
Bridge ( only by Selection of 2 faces ) SBridge by MaxSmirnov
http://moi3d.com/forum/index.php?webtag=MOI&msg=6674.254
Select all Boolean Union = it's a solid!
Normally Bridge kills automatically the bottom face !
when you Bridge a face from a solid volume to an "alone face" (not from another volume)
or a face from another subdivised surface! (not the case here ! )
So no need to Bolean Union !
But here it's a trimed face so boolean Union is needing!
Useful when you make subdivison!
et voila ;)
Not subdivision here just Shell...(it's a solid)
EDITED: 16 Oct 2020 by PILOU
9992.9 In reply to 9992.8
Classy render : )
9992.10
Perhaps a classic error when you loft in your your first try was to have made à caped loft.
You don't see the cap but moi don't know how to join for this case.
9992.11 In reply to 9992.10
<< Don't know how join on this case ...
Boolean Union will work ! ;)
For be clear...if possible :)
9992.13 In reply to 9992.12
Nice thread, is that [glassy render] simlab Frenchy?
I need to test pastic type materials... wondering what polygon setting would
you typically use to then "import" to simlab.
9992.14 In reply to 9992.13
Yep i use only SimLab (because it's very easy and permit to mix many 3D formats in the same time ) in free that is now 1920*800
or even SketchUp format! So no problem of regulate : you can play with smaller etc... if you have complex volume...
example with a model by thegoodguy
I have not made any special regulates (that was just for a test :)
Here SketchUp export from Moi : as you see you are not obliged to use OBJ format :)
A trick : export different objects against all in one if there are several complex objects!
You have another very cool free one (if you had loaded it previous year) : TwinMotion ! Without any limitation!
Updates are free too!
EDITED: 29 Oct 2020 by PILOU
9992.15 In reply to 9992.14
Hi Pilou, thanks for the tips over recent months. You are inspirational.;0)
Merci! Stefano
Show messages: All  1-2  3-15
