Question about CustomUI
All  1  2-4
9986.2 In reply to 9986.1
Maybe here?:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6507.331
and Michael's second post down?
Admin permissions?
Symlinks?
9986.3 In reply to 9986.1
Hi fcwilt
I just set up a second Object Library2, in AppData, and it works fine.
There were several steps.
Anton mentions possibility, but the details are sketchy:
http://moi3d.com/forum/index.php?webtag=MOI&msg=8824.16
1. Copy 70 ObjLibrary.js, to 71 ObjLibrary2.js, in the AppData startup folder. (My folder is called MoIAppData)
Edit 71 ObjLibrary2.js by: (for example):
renaming title line to "ObjLibrary2".
renaming menu line to "ObjLibrary2".
2. In the AppData customUI folder, by copy, rename, and edit, make ObjLibrary2.cfg, containing "Object Library;MOI\objects2".
also make ObjLibrary2.menu and edit the file in 4 places to "ObjLibrary2".
(Separate copies were made, rather than editing the original two files.)
3. Create objects2 folder in the AppData\Roaming folder, next to existing objects folder.
Admin. Priv. not needed for AppData, AFAIK, but may be needed for other locations?
(Windows10, MoI4Beta) (So MoI3 method would be a bit different?)
EDITED: 14 Oct 2020 by BEMFARMER
9986.4 In reply to 9986.3
I can try that.
I thought that in the version of CustomUI that works with Moi 4 that the only thing needed was to edit ObjLibrary.cfg.htm in AppData\Roaming\Moi\customui
If I do that the second one library name shows up in Moi. I can select and use the objects there, it's just that the icons don't display.
I'll take a look at your approach.
Frederick
Show messages: All  1  2-4
