Question about NodeEditor "Switch" Node
 1-5  6-25  26
9984.6 In reply to 9984.5
Thanks much, it works a treat.
So I rename the macro and export to the Moi macro directory?
Then to use it I import it?
Frederick
https://www.youtube.com/watch?v=f4OVZd5Faws
CCW click area, plus CW click area would be nice?
Dial or Rotary switch.
Four zones, each 3 step, 4 pole.
A DPDT, or 3PDT, or 4PDT would also find uses.
- B
SwDPDT.js is an extension node Widget, which performs like a Double Pole Double Throw switch.
To use it, save it in the nodeeditor extensions folder.
It is a modification to Max's Switch node.
The upper output is output (#0), same as for Switch node.
The NC output is a No Connection dummy output (#1) to line up output #2 for the second ctx "wire".
SwDPDT_demo.zip is a nod program to demo the connections. (Uses James circle/square technique, with second
switch chosing between rectangle and polygon.
Both switches change I/O state with the same mouseClick.
Both switches are the same datatype. Choose one of either numpoints, pointarrays, or objectlist for both switches..
See second post down for updated files.
EDITED: 15 Oct 2020 by BEMFARMER
9984.9 In reply to 9984.8
So the input output linking "wire" is drawn on the javascript canvas with ctx methods/commands.
Possibly with nodeeditor modifications.
Google search of (ctx canvas javascript) brings up explanations and examples.
For example: https://www.w3docs.com/learn-javascript/canvas.html.
So drawing the second wire should be relatively easy.
Duplicate some code, and adjust the y values for "startpoint". "endpoint" may be the same y "offset".
9984.10 In reply to 9984.9
https://developer.mozilla.org/en-US/docs/Web/API/CanvasRenderingContext2D/bezierCurveTo
After study of the bezier inputs, and much trial and error, the second "wire" was successfully located in the node box.
Updated versions are here. For the 3 people who previously downloaded incomplete node, please re-download.
See post 14 for 3rd version of SwDPDT.js, in swDPDT_3.zip file.
EDITED: 16 Oct 2020 by BEMFARMER
Size: 78.6 KB, Downloaded: 33 times, Dimensions: 732x553px
9984.11 In reply to 9984.10
There is a bug in datatypes/colors. Upon reloading saved nod program, Outputs 1 and 2 are teal color.
9984.12 In reply to 9984.11
On the node javascript, add a ctx.save() before starting the ctx drawing and end with a ctx.restore();
Wayne
SwDPDT2.prototype.onDrawForeground = function(ctx)
        ctx.save(); // save the context so we don't mess up others
	this.onDrawVectorSwitch(ctx);
        ctx.restore(); // restore context to what it was on entry
EDITED: 16 Oct 2020 by WAYNEHILL5202
9984.13 In reply to 9984.12
Thank you Wayne, but the bug persists. I inserted your two ctx code lines in the prototype, around the existing this... code line.
The bug is that after the demo.nod is saved, when the demo.nod is reloaded, the NC output dot, and the output dot below it,
appear as numarrays, teal in color. (Yet the two gold wires are still connected to them.) The SwDPDT works initially, but the two numarray outputs
do not act as gold objects.
It seems odd that Max's code for Switch, works fine on reload, but the modified code does not.
Maybe check some other node with two or three outputs?
For another node, I tried doing a "push button" "rotary" switch, with one output, and several inputs, sequentially individually connected to the output by mouse click,
but code would need some major alterations, not to mention understanding the existing code. The button option would probably not be appropriated for rotary.
Not a very standard switch. Maybe call it SinglePole4Throw? SP4T or SP5T, etc.?
9984.14 In reply to 9984.13
Split has dynamicOutputs.
Changing dynamicOutputs line to this.dynamicOutputs = ["*"];" seems to have cured the bug.
([0,1,2] would work too.)
Demo node file appears OK.
New zip of SwDPDT.js file below, named swDPDT_3
(Please delete old version, for those 3 people who downloaded it :-)
Here is an experimental version of SwRotary.js, a "push button" rotary switch.
The TicTac version (Up Down counter) is working, as default mode.
The mode selection is not set up yet.
The Cycled version did not work. Needs a little more work.
Should cycle from pole 5 to pole 1.
Reverse Cycle could be another mode?
Button mode removed as not appropriate. Mouse up code not modified.
The "wire " is not changing colors.
Demo nod program attached as well.
Some of the code for the different beziers is still present, but commented out.
It was used to figure out which values to use for the different beziers, for proper alignment with poles.
Have not tried any "Fork" versions.
See post 19 for "Final" working version.
EDITED: 20 Oct 2020 by BEMFARMER
9984.16 In reply to 9984.15
Why was Button mode not appropriate?
Thanks.
Frederick
9984.17 In reply to 9984.16
Well, I am mistaken, the Button mode could be used to temporarily bump up one pole.
Or else slowly scan through poles? Scan mode?
So I'll plan on adding Button mode.
Note, Button mode means to change connection while the button is pressed, (mouse down), and revert when the button is released, (mouse up).
9984.18 In reply to 9984.15
Modifying one line corrects the wire color bug.
(Only Inputs which are hooked up show the the wire color matching the datatytpe, which is nice.)
(Also for SwDPDT, wire color is NOT neutral for non-hooked up inputs, call it a Bug in SwDPDT.)
// if (this.isInputConnected(this.internal.on*1)) { ctx.strokeStyle = LGraphCanvas.link_type_colors[this.inputs[0].type];}
if (this.isInputConnected(this.internal.poleIndex)) { ctx.strokeStyle = LGraphCanvas.link_type_colors[this.inputs[0].type];}
(No more corrections, due to short term Travel, so corrected SwRotary not updated yet.)
9984.19 In reply to 9984.18
With a vary minor addition, "Cycled" mode is working.
Both modes advance pole by pole, from first pole to last pole.
Then:
By push button, Cycled mode jumps from last pole to first pole. (delta = -5)
Or, By push button, Tic-tac mode reverses (delta = -1), from last pole to next to last pole, etc, back down to first pole.
Mode may be changed in the Info box.
Wire color is working.
"Final" version attached.
No plans for "Button" mode, at this time.
9984.20 In reply to 9984.19
Thanks for the work.
I'm having a senior moment here - what do I do with this file?
Frederick
9984.21 In reply to 9984.20
The two new switch nodes should be copied to the %AppDate% > nodeeditor > nodes > extensions directory.
The switch nodes then get loaded by the nodeeditor program, to the Widget menu.
Existing Widgets of Max are not changed. Max's Interface.js file is not changed.
These nodes are separate files, but are based upon Max's code, with some modifications made.
After much study, the "arcane" to me code starts to make a little sense, but is still not totally understood.
The two files could be sequentially listed in a combined file, in the future.
9984.22 In reply to 9984.21
OK copy to the folder - got it.
But I've gotten lost somewhere along the way - you mentioned two new switch nodes.
Just to be sure can you tell me the file names again - I think I've seen all your postings but maybe not.
Thanks.
Frederick
9984.23 In reply to 9984.22
Well, there is swDPDT.js, and swRotary.js, which show up in the widget menu with capitalized S.
9984.24 In reply to 9984.23
Thanks.
Those are the two I have - just wanted to be sure I was still in sync with you.
Do you think there were would be a way to allow selecting any input on the "rotary" switch, as opposed to having to step through each position to get to the desired position?
Frederick
9984.25 In reply to 9984.24
Here is a quick partial demo, after very limited thought...
Create a temporary circle or square, by mouse click on standard Switch widget, in Button mode. (First hit Run).
Logic Split node, mask...
(Or switch the two switches to Switch mode. Might want to add some other logic gate, so only one mask is active at a time?)
Show messages:  1-5  6-25  26
