Project Curve > project only to front
All  1-2  3-9
9980.3 In reply to 9980.2
Hi Grand Master of subD ;-)
I remember having seen this option but it somehow vanished.
I cant find it in the menu so what do I need to activate that function ?
9980.4 In reply to 9980.3
Call Construct / Project then...
9980.5 In reply to 9980.4
Ahhh ;-]
NOW ! So obvious but I had missed it till now.
Thank you very much, Pilou , you are always incredibly helpful !
9980.6
Hmm ;-(
"Closest point" is not the same as "front surface, it distorts
the projected curve in search for the closest points, have
you realitzed that, Pilou ?
9980.7 In reply to 9980.6
Depending of the nature of the curve, the nature of the target surface, the nature of what do you want ...
How do you want project a curve on a sphere without deformation ?
EDITED: 12 Oct 2020 by PILOU
9980.8 In reply to 9980.7
I meant deformation relative to the deformation of the parallel projetion,of course.
9980.9 In reply to 9980.1
Hi Tom,
> Is it possible to get MOI to only project the curve onto the frontside ?
Sorry no, not currently. For now you will need to delete the back one, or split the target object so it doesn't have multiple pieces projected onto it.
I would like to do an overhaul of the project command in v5. Also the "closest pt" option tends to produce bad output, it isn't really usable currently either.
Show messages: All  1-2  3-9
