any plans for 3ds suport?
All  1-2  3-8
998.3 In reply to 998.2
sorry i ment importing 3ds file format.
i been doing some Achitectural tests with Moi and Maxwell,
most of furniture/object libraries on the net are in 3ds format.
it would be really helpfull if i could import/remodel, use for interior/exterior viz.
Ps.I did test moi with some product/furniture designs, IT DID NOT LET ME DOWN ONCE
998.4 In reply to 998.3
Hi Yannada, I see now. The problem is that MoI isn't really currently set up to work with polygon mesh objects, just NURBS objects.
But one thing I've been planning on doing is making a converter program that would take a polygon mesh file and extract the wireframe of the polygon mesh as line segments and write that to a .3dm file. That would let you work with the lines in MoI to snap on to, etc...
I'll see if I can give that a try sometime next week. At first I was going to focus on converting from OBJ format though, do you have something that can read .3ds files and output .obj ?
998.5 In reply to 998.4
some time ago using 3dsmax, not anymore 100% Maxwell a year now.
a converter program. would be great......thanks
998.6 In reply to 998.5
sorry i almost forgot i could import .3ds in Silo3d and export as .obj.......then?
998.7 In reply to 998.6
> .......then?
Then you need to use a converter program that I haven't written quite yet, hopefully I can get to it later this week.
998.8 In reply to 998.7
cool
Show messages: All  1-2  3-8
