Surface error on imported STEP & Iges Files
All  1-2  3-5
9975.3 In reply to 9975.2
I use the last version of Rhino5... i see no reason to upgrade to V6.
I just bought Ablibre Design Expert... its good to have a parametric modeller.
Could you add a function to display the inner surface in a different color? Like in Rhino?
or naked edges in a different color? This is what i find very useful in Rhino.
I have attached the step file...
EDITED: 13 Feb by BLACKBIRD
9975.4 In reply to 9975.3
Hi BlackBird, thanks for sending the file. I have put it on my list of things to investigate.
I want to have those but they aren't going to make it in for MoI v4. You can select naked edges to see where they are though, that can be done by selecting an object, then using "Details..." and at the top in the "Type:" report it will tell the number of naked edges and you can click on that label to select them.
Or also there is a script you can set up on a shortcut key here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6051.2
9975.5 In reply to 9975.4
Oh how cool ist that. i didn know about the buildin edge-analysis.
I am allways suprised about all this not so good known features.
You realy think about alot of things.
Keep up the good work.
Show messages: All  1-2  3-5
