eps, pdf
All  1  2-6
997.2 In reply to 997.1
Hi Gyuri,
> Is, it possible to convert bmb into eps, or Pdf, then import to Moi as an editable curve?
It is possible, but the complication is that both eps and PDF can also contain bitmaps inside of them as well as curve vector information.
Probably the conversions you are doing are resulting in embedded bitmaps inside the eps or PDF files.
You need a more specialized "vectorizer" program that will actually try to trace the outlines of your bitmap with curve objects, rather than just translating the bitmap over. I'm not really too familiar with these programs myself, but I think there are several different ones available, maybe someone else has some experience with some of them.
Also .eps files can sometimes more difficult for MoI to read, so you should try to convert to .ai or .pdf instead if that is possible.
997.3 In reply to 997.1
for MoiImport, PDF-File and AI-File needs vektordata info in the file.
Moi is not raster to vector converter.
Gimp produced rasterformat.
For vektor see:
www.mayura.com (Mayura Draw Vector Drawing Program)
www.deneba.com (Deneba Canvas)
www.inkscape.org (Inkscape, only svg)
www.adobe.com/de/products/illustrator (AI)
MS-Office, Open-Office ect....
BestReg`s EDDI
997.4 In reply to 997.2
You also might search for the phrase "Raster to vector" for some more information, here are some links:
http://en.wikipedia.org/wiki/Raster_to_vector
http://graphicssoft.about.com/od/bitmaptovector/Bitmap_to_Vector_Conversion_Tracing_Software_Raster_to_Vector.htm
http://wiki.inkscape.org/wiki/index.php/Tools#Vectorize.2Ftrace
I'd say probably try Inkscape at first...
997.5 In reply to 997.4
Hi EDDi and Michael
I, ve tried with Inkspace, It works.
Thank's
Gyuri
997.6 In reply to 997.5
If you're into cartooning, I hope you're familiar with Moho (now called "Anime Studio"):
http://my.smithmicro.com/win/animepro/index.html
I thought that it supported illustrator exports, but I see it only has Flash export.
Character construction and animation is very cool with this application however and I love the fact it's vector based and uses bones for animation.
-Will
Show messages: All  1  2-6
