How can I achieve this please?
 1-3  4-23  24-36
When you have your points in Moi for make the surface you can use the Delaunay Node of the Node Editor Elephant
EDITED: 29 Sep 2020 by PILOU
9967.5 In reply to 9967.1
Hi Sutts,
What format is your terrain data in?
The ImportPointFile can import .txt, xyz, or csv (an excel export type).
The file can have a few kinds of delimiters, as I recall.
The freeform curve option might be nice. Not sure just how it works, or how the data should be formatted...
A little experimentationn might be in order?
Maybe you could post a small sample of the data?
https://moi3d.com/forum/index.php?webtag=MOI&msg=9005.2
Forum search of ImportPointFile brings up numerous links.
I have yet to see much documentation on the ImportPointFile script.
A matrix of rows and columns of terrain data???
EDITED: 29 Sep 2020 by BEMFARMER
9967.6
Pilou, Brian,
Thanks so much for the help - have lots to try out now.
I have a heightmap tiff image to work with but I can process that to pull out the data in any format I like.
Will have a play and let you know how I get on.
Dave
If your points are inside a csv file
here for 20 points randomized inside a spreadsheet ;)
9967.8
You can use Max's HeightMap script with the heightmap picture. Use Loft after the curves are generated.
http://moi.maxsm.net/
Wayne
Ref: From Mount Rainier heightmap
https://mattbooty.wordpress.com/2019/01/20/3d-printing-a-model-of-mount-rainier-using-digital-elevation-model-dem-files/
EDITED: 17 Jan 2021 by WAYNEHILL5202
9967.9
Thanks again for the pointers. I have some good news and some bad news....
The good news is that I managed to convert the ImportPointFile scripts to import multiple polylines from a single CSV file (1 polyline per data row).
This works well and the resulting curves simply require 2 joining lines - one along each end - to produce something that can be networked into a surface.
The bad news is that MOI struggles badly with networking the area I'm working on - in fact it never completes the job.
The area is approx. 2400m x 2400m with data sampled every 1m. That results in 2400 polylines, each line with 2400 data points.
That means we're connecting close to 6 million data points. I'm sure I could resample it but I need that level of detail I'm afraid.
Can anyone advise on a way forward please or suggest an affordable modelling package that might handle that kind of landscape size?
It's frustrating as I thought I was almost there. MOI is an incredible piece of software and I use it for all my modelling now. It's got to be the most well thought out modelling package out there but I suspect I'm pushing the boundaries here.
9967.10 In reply to 9967.9
Are you using MoI4 Beta? It handles more data... or memory or ...
I think I would use interpcurves instead of polylines.
9967.11 In reply to 9967.10
I am Brian, yes.
9967.12 In reply to 9967.11
Maybe try Through pts import option?
Divide up the problem into 4 or 16 or 64 grid areas?
Try out a smaller grid for proof of method?
9967.13 In reply to 9967.12
Also it is unclear if you are doing "column" polylines, or "column" through point curves.
Or just joining the ends of the "row" polylines?
I would think that there should be multiple columns of curves, about the same as the row curves.
Are you trying to network ribbons, or a grid?
A reduced size demo "3dm" would be nice to see?
9967.14 In reply to 9967.13
I think Network works on a grid, "quad-ish", like a very wavy screen door screen.
- B
You would need to do a second data set in column format?
9967.15 In reply to 9967.12
Thanks for the suggestions Brian. I'll try that.
Maybe if I make a surface for each of the smaller units and remove the polylines, I can then join the surfaces up with a smaller hit on memory/processor.
Maybe Loft?
Networks seems better way?
- B
Let P be a matrix of points. Just the raw point.z values need be stored. ( Pt.z ).
The row numbers are the x coordinates (possibly scaled a bit).
(Or store all the raw point data, Pt, with Pt containing (Pt.x, Pt.y, Pt.z))
The column numbers are the y coordinates (possibly scaled a bit).
P is a javascript array of arrays, and is zero indexed.
P[i][j] = P[row][col] is of dimension 2,400 by 2,400 = 5,760,000 z values.
The entries of P can be accessed by row, or by column, to create the curves.
If there is too much data, smaller chunks of P could be accessed, either n rows, with all columns,
or vice versa, or rectangular subsets of the matrix could be accesed.
Well, a few thoughts anyway.
I wonder if the surface edges/ surface results of network chunks join up the same as the surface result of a complete network?
And what are the geometry data limits of MoI4?
9967.18 In reply to 9967.17
Mmmm, good point Brian. Will have to experiment to see if the chunks will join along their edges.
9967.19
I've created a much reduced data set with just 20 curves for testing (attached).
I also include 2 images to show the resulting model before and after the surface has been applied. All works very well, although the network operation takes time even with this many curves.
Size: 319.6 KB, Downloaded: 46 times, Dimensions: 1920x1080px
Size: 233.5 KB, Downloaded: 50 times, Dimensions: 1920x1080px
9967.20
And here is the modified script I used to load the multiple curves. It was a quick job and I've only tested it with Polylines!
9967.21
Here is the 3dm file for the model before I remove the polylines from the surface.
9967.22
And here is the final surface with a basic road aligned above it, ready for projection.
Trouble is, I can't get it to project onto the surface for some reason. I've used projection before without issue.
Any ideas please? Thanks!
9967.23 In reply to 9967.22
Seems your object is out scale of the Origin !
Default Grid is 300 * 300
Your object is 123 600 * 2 000
Show messages:  1-3  4-23  24-36
