Edges & Visuals
All  1-14  15-17
9958.15 In reply to 9958.14
You can solve this by hiding the other objects so only the one you need to work with currently is visible.
>> Will start using that for sure.
So you mean the vertical lines but only the ones on the outermost surfaces? Right now I can't really see an easy way to identify those using script.
>> Yes in this instance it would be like this picture shows.
I would recommend using 2 window selections like you show [ + 'wireframe' + spellcheck ]
- Stefano
edit: 15th May 26, squashed image, nothing new here.
EDITED: 16 May by LIGHTWAVE
9958.16 In reply to 9958.15
Hi Stefano, I guess if you had a center point to reference then in that case a script could evaluate the surface normal at say the midpoint of the edge and see whether that is pointing towards the center point or away from it.
9958.17 In reply to 9958.16
Hi Michael, as these are always regular shaped 'frames' I can presume there is always a "box" centre. It's good to know theres always a way.
Learnt a lot about manual selections on this one so likely i can already work 50% faster.... Originally selecting those inner verticals with solids in the way was 'fun' as I orbited around the contours. Thanks again - Stefano
> Wireframe Shortcut Script:
script:var breps = moi.geometryDatabase.getObjects().getBReps(); var hide = true; for ( var i = 0; i < breps.length; ++i ) { var faces = breps.item(i).getFaces(); if ( i == 0 ) hide = !faces.item(0).hidden; faces.setProperty( 'hidden', hide ); }
Others of interest here:
http://kyticka.webzdarma.cz/3d/moi/#ShadedDisplayMode
Will be trying this 'adjacent edge' loop script also...ref Michael post
# 3112.22
script: /* Loop selection */ moi.geometryDatabase.selectLoop();
EDITED: 28 Sep 2020 by LIGHTWAVE
Show messages: All  1-14  15-17
