Edges & Visuals
All  1-13  14-17
9958.14 In reply to 9958.13
Hi Stefano,
> the issue i am finding is I will be selecting other objects usually on drag selecting. Then its another de-selection.
You can solve this by hiding the other objects so only the one you need to work with currently is visible.
A quick way to do that is to select your object of interest and then right-click on the Edit > Hide button. That will trigger the "Isolate" function which will hide other objects and only leave the selected one showing. When you're done right-click on Edit > Hide again and things will return to the same visibility state as before the isolate.
> I'd be interested to know if all the colours I am showing as 'EDGE selection groups' in this video
> could actually be 'identified' by a script. Ideally, few click solution.
So you mean the vertical lines but only the ones on the outermost surfaces? Right now I can't really see an easy way to identify those using script.
I would recommend using 2 window selections like you show.
9958.15 In reply to 9958.14
>> Will start using that for sure.
>> Yes in this instance it would be like this picture shows.
I would recommend using 2 window selections like you show [ + 'wireframe' + spellcheck ]
- Stefano
edit: 15th May 26, squashed image, nothing new here.
EDITED: 16 May by LIGHTWAVE
9958.16 In reply to 9958.15
Hi Stefano, I guess if you had a center point to reference then in that case a script could evaluate the surface normal at say the midpoint of the edge and see whether that is pointing towards the center point or away from it.
9958.17 In reply to 9958.16
Hi Michael, as these are always regular shaped 'frames' I can presume there is always a "box" centre. It's good to know theres always a way.
Learnt a lot about manual selections on this one so likely i can already work 50% faster.... Originally selecting those inner verticals with solids in the way was 'fun' as I orbited around the contours. Thanks again - Stefano
> Wireframe Shortcut Script:
script:var breps = moi.geometryDatabase.getObjects().getBReps(); var hide = true; for ( var i = 0; i < breps.length; ++i ) { var faces = breps.item(i).getFaces(); if ( i == 0 ) hide = !faces.item(0).hidden; faces.setProperty( 'hidden', hide ); }
Others of interest here:
http://kyticka.webzdarma.cz/3d/moi/#ShadedDisplayMode
Will be trying this 'adjacent edge' loop script also...ref Michael post
# 3112.22
script: /* Loop selection */ moi.geometryDatabase.selectLoop();
EDITED: 28 Sep 2020 by LIGHTWAVE
Show messages: All  1-13  14-17
