I miss 123d Design (the Fillet master)
 1-11  …  32-51  52-71  72-91  92-96
9952.72 In reply to 9952.70
Hi Psygorn, it looks like you've got some edge fragmentation in the surface before you shell:
the other thing that's kind of problematic with your shape here is with this edge being a trim curve on a plane:
If you make a blend off of that, these edges will not be smooth to each other even though the surfaces are smooth where they touch:
If that edge was a natural edge of the underlying surface then you would get both surface and edge smoothness there.
it would probably be best to make that one single longer surface instead.
9952.73 In reply to 9952.71
Hi Psygorn, for the tiny edges it would be good to get rid of them using Merge.
"There are tiny edges that were not selected by Blend"
Blend does not itself select edges, to make the blend include the tiny edge you would need to also select those tiny edges before doing the blend so they are included. But getting rid of them would be good too.
re: "And Blend makes it warped"
Blend is deciding to reverse one of the edges, you can override that by clicking on the edge while in the blend options, it will then flip to the direction you need.
But Blend might not be the best here anyway, it will make a surface that is smooth to the other surfaces but the "side edges" will not be smooth to each other.
You would get smooth side edges if the edges being blended were also natural edges of the underlying surface like if they were the end of a loft or sweep surface instead of being a trim curve that's on a larger underlying surface.
9952.74 In reply to 9952.71
Hi Psygorn, try shelling and filleting with this attached version. It's got both smooth surfaces and also "side edges" as well.
9952.75 In reply to 9952.74
Hello and thank you Michel,
So I made refined the object a bit I used Extrusion , Blend & loft to create it then imported it in 123Ddesign and then after applying fillets imported it back to MOI.
But I saw an artifact! take a look at below image.
If everything goes well I can create a Linked-Star Object.
You can see one here:
https://filesend.io/188cbf8bb71592fbc6871b1468e781c5/Linked_Star_Filleted_With_123D.3dm (@PILOU I think it is a good subject for rendering :-)
But it is not a solid object. it is a joined object. So, if I can rectify this issue I would be able to create a Linked star in MOI :-)
9952.76 In reply to 9952.75
Hi Psygorn,
It appears to possibly be just a display mesh artifact, if you export out the export mesher works fine there. So just ignore that display artifact.
Well it's pretty easy to see why it's not a solid, the end pieces are missing:
If you draw a line down the middle:
You can then select the line and edges like this and use Construct > Planar to build a cap there:
Use Edit > Join after those have been created to join the caps to the main piece to make a solid.
- MIchael
9952.77 In reply to 9952.76
Oh dear Michael u got me wrong! :-)
I was talking about something else!
I was talking about this 3dm file: https://filesend.io/188cbf8bb71592fbc6871b1468e781c5/Linked_Star_Filleted_With_123D.3dm It is the one that is a joined surface and not a solid! This is the one that if I could fix it I'd be happy :-)
The Object u showed in your previous message has to be open! I left it open on purpose :-) otherwise I cannot have my Linked-star object! :-)
EDITED: 31 May 2021 by DRILLBIT
9952.78 In reply to 9952.77
Hi Psygorn, sorry I didn't understand properly. That other one looks like it has some pretty messy areas:
That sort of looks like pieces that were copied around a center point where the objects were not quite aligned with the center point.
Do you have a version of this before doing the filleting?
It looks like there are some areas that do not have naked edges, so one approach could be to delete problem areas and copy some good pieces without naked edges into that spot.
9952.79 In reply to 9952.77
Hi Psygorn, maybe it would be good to start a new thread for your star object and also try to share any .3dm files you have for earlier stages of the model.
It's a complex object and it would probably be a good idea to make sure the earlier pieces are very accurately positioned.
9952.80 In reply to 9952.78
Hi Michael, :-)
Yes I noticed that! but I want to learn how I can fix it! then MOI would be enough for me to create such complex geometries! (No need to mention I love complex Geometrical shapes :-)
Yes, U can do it yourself just try to make copies of the open object.
I already shared it with you :-) Do you remember "Single_Piece_Modified_with_123Ddesign.3dm" in theory you should be able to create the Linked-Star with that object.
But in reality I think you might face some issues and end up having a joined surface.
9952.81 In reply to 9952.79
Ok, I will and What name you suggest for the thread? Linked-Star?
Of course I tried to have everything positioned perfectly but u know, it seems somewhere some deviation gets in the way!
9952.82 In reply to 9952.81
Hi Psygorn,
Sure that's fine.
9952.83 In reply to 9952.80
Hi Psygorn,
Do you have this piece before it was sent into 123Ddesign for filleting?
9952.84 In reply to 9952.83
Hi Michael :-)
I am getting the hang of it! I did it in MOI only! :-) But it is not fillet-able in MOI.
This time I made the whole Object in MOI then exported it as STEM and then imported the whole model in 123Ddesign. it was a bit hard to select edges I wanted to fillet but I can say it is doable! :-)
Edit: And if you want to see the filleted version it is here (I might have missed some edges) :
https://filesend.io/bb7704265296e30e71f1af2ed7fa3bd3/Original_MOI_Piece_Filleted_in_123D.3dm
9952.85 In reply to 9952.84
HI Psygorn, that's looking really good now! The MoI filleter seems to be having a problem where it's not extending fillets to meet each other in a some spots. It constructs a bunch of the fillet surfaces but it's not able to trim the main body because of the missing pieces.
And yeah this method of building the whole thing first and then putting fillets on at the end seems more manageable than putting on the fillets before assembling.
Hi Psygorn,
nice model.
sjoo (R.I.P) invented the Linking Stars model more than a decade ago, based on a model
from Bathsheba Grossman and my friend Jotero an I did also remakes of the model.
Maybe interesting for you and others to take a look at. I included also a basic .obj file
you can use with MoI's sub-d importer.
https://ipfs.io/ipfs/Qme4gNiLw5z7DjtXMv74jHJBTPLyUZXW59MrVsdYF1uaTU/LinkingStars
And popularized by the stuning prog free TopMod! ;)
http://people.tamu.edu/~ergun/research/topology/download.html
A topologic Modeler
Because it was some easy to build it with TopMod!
my little album https://issuu.com/frenchy_pilou/docs/topmod
The UI of TopMod
EDITED: 2 Jun 2021 by PILOU
Yes, the good old TopMod days. :-)
In the middle of the TopMod Gallery one can see sjoo's first LinkingStars design.
https://www.deviantart.com/sjoo/art/LinkingStars-Part-1-64482927
9952.89 In reply to 9952.86
Hi STEFAN,
Thank you for the information! I am interested in complex geometrical shapes.
I did not know sjoo(R.I.P) had invented linked-star! To me it is really interesting when I think there might be shapes or 3D object that could be invented!
Do you happen to know nice Forums in which people share knowledge about Geometry ( Specially 3 dimensional Geometry) I would like to know more about these objects. for example I just think there are similarities between Celtic knots and Linked-Star but I don't know for sure.
Hi Psygorn,
unfortunately, so it seems, the days of 3D MathArt are over.
My friend Jotero (Torolf Sauermann leader in 3D MathArt) run for
many years such a forum, where also sjoo, Pilou and others participated.
But he was many times ripped-off by companies and individuals and
also never received any support much, in form of, for example,
donations.
The only thing you can do is trying to find more resources about this
topic if you google for him, which may lead to other interesting links.
To get you started:
http://www.evolution-of-genius.de/gallery/default.htm
http://jotero.com/
And google for 'Torolf Sauermann'
Sorry that I can not be of better help!
P.S. Brian, here on the MoI Forum, is the only remaining
person, who does 3D MathArt related things with scripting
in MoI.
Best regards
P.S. If you have Instagram you can follow Torolf there.
I do not have Instagram, but IIRC he shows there plenty of 3D Fractals.
Show messages:  1-11  12-31  32-51  52-71  72-91  92-96
