I miss 123d Design (the Fillet master)
 1-7  8-27  28-47  48-67  68-87  88-96
9952.48 In reply to 9952.46
Hi Psygorn,
> Even when I select edges that are not coming from a shared vertex I don't get a fillet for this particular example!
I'm not able to repeat that over here, see my examples above where all edges are being targeted, fillet is working ok then.
Can you show me a case with your objects where it's not working when all the edges coming off of a single vertex location are being filleted instead of only some of them?
> I have a solution to my problem but I am just curious as to why fillet doesn't work for hexagonal
> pieces here! but it works for pentagonal ones!
Well like I mentioned above when only some of the edges at a juncture area are being filleted it's a much more difficult case for the filleter to handle because it needs to do more work to extend and intersect fillet surfaces against each other. Those are pretty difficult calculations. As to exactly why it works for the fillet surfaces on your pentagonal cases and not your hexagonal ones, that's probably some sort of bug in the fillet intersector. It would probably take me something like 20 to 30 hours of investigatory work to try and answer it any better than that.
In the same order of case...
curves must be always on the same plane ?
9952.50 In reply to 9952.47
Sorry, I was wrong! When I said : "Fillet doesn't work even if edges come from a not shared vertix" ( I simply did not count for Vertixs of Back faces )
Thanks for your guide I was able to successfully join all the hexagonal outer surfaces. ( check the attached file)
However, I come upon new question how could I select loop faces like the image below? ( I know an script which will let user to select looped edges)
9952.51 In reply to 9952.49
@ Pilou,
Yes for curve filleting the segments around the corner to be filleted must be on the same plane.
For a non-planar curve like you have there you might try cutting away some space and then using Construct > Blend to put in a blend curve.
9952.52 In reply to 9952.49
Hi PILOU,
Take a look at below image:
Edit: And the attached file.
9952.53 In reply to 9952.50
Hi Psygorn,
Sorry I don't know of any script currently available that would automate that selection.
9952.54 In reply to 9952.49
And PILOU, sometimes it works without any problem!
Check the attached file.
9952.55 In reply to 9952.53
HI Michael,
Should I make a wish for it? ( On MOI V5 Wish list?) Or it is not doable no matter how hard I wish for it?
9952.56 In reply to 9952.55
Hi Psygorn, you can certainly put in a wish for it. To make an actual script for it I would probably need a more specific description on how it should function and more examples. Otherwise it would be too easy to end up with a script that worked for this particular case but not in others.
9952.57 In reply to 9952.54
@ Psygorn
Have you tryed with 123D for example ?
Tested : working! ;) here with different values...
EDITED: 21 May 2021 by PILOU
9952.58 In reply to 9952.49
@Pilou
Not so parametrable as Filet, for non planar curves, you can use the Max's "DelCorners" script.
If you want tune how much your curves will be round, you can use, before "DelCorners", a "Rebuild" (with Pts number) to define it.
Few possibilties for this tuning, but : Tested and it works !
I think it's easier than a blending process which has to be done step by step between 2 curves each time.
9952.59 In reply to 9952.58
Indeed some impredictable but very smooth! :)
here use of Delcorners (but planar) + ExplodeMove
else without Delcorners (but planar)
EDITED: 22 May 2021 by PILOU
9952.60 In reply to 9952.57
Hi PILOU, unfortunately not because I don't have 123D on my machine!
9952.61 In reply to 9952.60
9952.62 In reply to 9952.56
Sorry for my late reply :-)
Here it is what I meant:
Needless to say I have learnt this from my experience with Blender.
9952.63 In reply to 9952.57
Hi PILOU! OH WOOOW,
For some reason I was not able to see your attached image, Now I saw it! It looks amazing :-)
9952.64 In reply to 9952.62
Of course not exactly that you want but you can try this (many sort of selections you can edit that you want)
https://moiscript.weebly.com/selection-loop.html
and
https://moiscript.weebly.com/select-by-length.html
https://moiscript.weebly.com/select-biggest--smallest.html
9952.65 In reply to 9952.62
Hi Psygorn, you might try the scripts on this thread:
http://moi3d.com/forum/index.php?webtag=MOI&msg=10262.1
9952.66
Hello all,
I need help from one of you who has access to 123D.
Please take a look at attached STEP file.
my problems:
1- when I import it to 123D design it is huge! ( I don't know how I can set its size) ( I know I can scale it but this is not what I want) Needless to say it is produced in MOI 3D.
2- I tried several times to perform fillet on it I got no fillet! 123D design gave me error!
So, is it possible one of you could check it?
9952.67 In reply to 9952.66
Hi Psygorn, can you post the .3dm model file as well?
The large size might have to do with units being set to meters.
Show messages:  1-7  8-27  28-47  48-67  68-87  88-96
