I miss 123d Design (the Fillet master)
 1  2-21  22-41  42-61  62-81  82-96
I would not download from such links, only from well known sites.
9952.23
In my opinion https://web.archive.org/ is more secure place than the others. This is only backup so If site was virused then it backuped it as is. www.123dapp.com was also secure site I think. This is only my opinion but I wouldn`t aware those both site. I don`t know is it possible to switch file to virused one but if it`s possible then it`s possible everywhere.
9952.24 In reply to 9952.23
This link is still working: https://autodesk-123d-design.en.lo4d.com/windows
it is the official download link, btw !
EDITED: 9 May 2021 by OKURO
9952.25 In reply to 9952.24
I am not sure that is the official one!
It's just a Donwnloader of progs! ;)
https://www.lo4d.com/corp/about
But will be very cool if you can install it!
9952.26
I've uploaded Autodesk 123D_Design_R2.2_WIN64_2.2.14 on Gofile, here's the link :
https://gofile.io/d/w0eOO9
I've intergrated in the archive, the manual and shortcuts guide aswell.
It works perfectly if you launch it offline, if not, you will not be able to exit the program properly unless killing the task.
9952.27
Thank you guys :)
By the way could anyone of u compare Onshape with 123D Design? it terms of lightweightness & filleting ability?
I also faced few problems regarding Uninstallation of Fusion 360 (I know this is not a place to seek help for that ;) but I thought maybe any one of you could help, So, If u think you can help I will tell u what my problem is!)
9952.28 In reply to 9952.27
OnShape is a monster like Fusion 360! ;)
123D is a lighter one !
both can resolve some of complex fillets
Uninstall fusion 360 must be done (in windows) like usual other progs!
Config Panel / Uninstall Progs...
EDITED: 10 May 2021 by PILOU
9952.29 In reply to 9952.28
Yes it should be like what you mentioned above, except the fact that it doesn't work! Windows was not able to uninstall it ;)
So, I did a research and found this:
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-do-a-clean-uninstall-of-Autodesk-Fusion-360.html
According to above website :
1-Go to the Start Menu > Control Panel > Uninstall Programs.
2-Select the existing Autodesk Fusion 360 entry from the list and click Uninstall.
-> *Sometimes this step will not work depending on what happened to the installation files. If that is the case move onto the manual deletion steps below)*
In my case this didn't work! So, I went to this link:
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-do-an-automatic-Clean-Uninstall-for-Autodesk-Fusion-360.html
and downloaded "Fusion_360_Cleaner.zip for Windows" and then executed it! It seems it was able to remove Fusion 360. But my problem is that when I go to Control Panel\All Control Panel Items\Programs and Features I still see Fusion 360 ( however the icon is not there but it says it has occupied 2.54 GB on my drive!
Edit: I just need a companion program for MOI to do the fillet job! While I am waiting for MOI to improve its filleting abilities :)
So, I am looking for a preferably lightweight and free/open source program. if you have worked with Onshape & 123D Design before which one you suggest?
9952.30 In reply to 9952.29
123 Design will be perfect because it's very easy!
Design Spark Mechanical 5.0 (free) is less easy and export / import with Moi is a little tricky!
OnShape is middle easy and only Online...
9952.31 In reply to 9952.25
YES: it is the official site !
9952.32 In reply to 9952.31
This one yes but... no link to 123D progs! ;)
https://www.autodesk.com/solutions/123d-apps
9952.33
Which version of 123d design is that? I think it`s the first iteration because later layers were turned off. I can`t find that old version with layers. Do you think that the older version is better than the newer one? I think it won`t try to connect with Autodesk and those layers are useful.
Do you have any opinions about that version from that screenshot?
Cheers!!!
9952.34 In reply to 9952.33
How about the fillet power?
9952.35 In reply to 9952.33
Why not click n the button "?" on the Top right screen ? ;)
9952.36 In reply to 9952.35
This was answer to my question?
Because I don`t have this software only print screen from net :) it`s hard to click anything on the image ;)
I can`t find this particular version. I`ve found others but not this one.
9952.37 In reply to 9952.36
From this "French Site" it's more a beta 123D (6.1) for Fusion 360...
Scroll/Click the Horizontal images : your is N°7 / 9
I believe that you can download it! Will be in English! ;)
Only for Windows! (not tested because i have yet 123DDesign 2.2.14 and Fusion ;)
https://autodesk-123d.fr.softonic.com
EDITED: 11 May 2021 by PILOU
9952.38
Hello to all,
Does anyone have any idea why moi cannot perform fillets on my hexagonal objects while it can perform fillets on pentagonal ones?
9952.39 In reply to 9952.38
Maybe because is like to try to fillet a sphere ?
9952.40 In reply to 9952.39
DRILLBIT -
If I select the solid(s) then I can fillet up to around 0.5. If I select just the outer face I can't get a fillet. Sometimes fillet needs multiple faces to be selected. I suspect it has to do with the smaller angle.
Michael would need to give the technical explanation - I just know what works :)
9952.41 In reply to 9952.39
Hi PILOU,
No! I don't think its the case then why MOI is able to perform fillets on pentagonal objects?
Show messages:  1  2-21  22-41  42-61  62-81  82-96
