Cage Edit
All  1  2-5
9951.2 In reply to 9951.1
I believe for the moment the only thing you can do is
Separate your volume
Modify each surface without (or not) move) "common points" depending of result wished )
Join when all surfaces are modified
here with only one surface of a cube...
EDITED: 13 Sep 2020 by PILOU
9951.3 In reply to 9951.2
not exactly that I want, but definitely it is a possible solution. thank you.
9951.4 In reply to 9951.1
Hi glmr, sorry no currently there isn't a Cage Edit function in MoI. It is something that I want to add in a future version though.
It is possible to use the Flow command to do some similar types of deformations, for example here's a flow from a base plane to one that has had its control points narrowed at the top:
9951.5 In reply to 9951.4
Thank you! Looking forward for a future version
Show messages: All  1  2-5
