Dimensions Feedback and Features
All  1-12  13-14
9950.13 In reply to 9950.12
Shortcuts kindly provided by Michael that help speed up / automate creation or management of dimension presets.
#1: Goes direct to ADD DIMENSION PRESET
script: /* Add preset dialog */ var dlg = moi.ui.createDialog( 'AddPreset.htm', 'resizeable,defaultWidth:26em,fixedHeight'); var res = dlg.window.doModal(); if ( res != -1 ) { var name = res[0]; var copy_from_index = res[1]; moi.geometryDatabase.addAnnotationPreset( name, copy_from_index ); }
#2: Goes direct to Options/Dimensions
script: /* Options dialog - dimensions */ moi.command.setOption( 'Options.htm_lastused', 'Dimensions' ); moi.ui.createDialog( 'Options.htm', 'resizeable,defaultWidth:43em,defaultHeight:32em' )
#3 Stefano 'shorthand' one for opening options dialogue box:
moi.ui.createDialog( 'moi://ui/options.htm','resizeable,default');
or
script: /* Options */ moi.ui.createDialog( 'moi://ui/options.htm','resizeable,default');
EDITED: 21 Sep 2020 by LIGHTWAVE
9950.14 In reply to 9950.13
When more than one object is selected or all objects selected its easy to get the annotation selections
Just click "details" or use a shortcut for object properties (as above post 9950.4):
nothing new here @ 18th May 26.
asides first post had rather large .giff, now on our cdn.
EDITED: 18 May by LIGHTWAVE
Show messages: All  1-12  13-14
