Socket Head Screws
 1-20  21-40  41-43
9949.21 In reply to 9949.20
Hi Frederick,
I have corrected the thread length issue and updated the Zip file in first post.
Please be aware that the thread length should always finish short of the screw length
else you will run the thread into the head.
Cap Screws and Button head screws are measure under the head but Countersunk Head Screws
are measured including the head so allowance for that is needed when setting the thread length.
I will look at adding a safeguard if possible.
Barry
9949.22
Hi Barry,
Changed to "Node Editor 1.1 jms".
Everything is working fine. Great Work!
Wayne
P.S: I am not going to say anything about threads missing in the nuts, because that has already been addressed. But... If I were to 3D print some nuts using this script, it would be another step, before the 3D build. Just thinking ahead....
EDITED: 14 Sep 2020 by WAYNEHILL5202
9949.23 In reply to 9949.1
So there are alot of guys doing great stuff with Max's NodeEditor. The unfortunate part is alot of customization for particulars makes it hard to keep a proper, working install of it.
I did a diff of the 2 node editors and there are some significant differences. But if Max updates his, then thats where the break for various users comes in.
I always kept a Perfect "Max" updated install. But this meant that most of these "Voila" nodes that get posted, dont work for me. As we have seen here with others.
Installing the JMS version works, but what about Max's version now (The changes werent just "add-ons, but actual changes to the functions)
Anyway, long story short, I decided to make a second NodeEditor button and folder, so I could just run the 2 side-by-side. (And also run anybody elses stuff that needs a custom setup)
Anyway, just a note that might help others with same consideration...
9949.24 In reply to 9949.23
I understand better now the curious name version v.1.1.2020.07.19.jms :)
9949.25 In reply to 9949.24
Hi Frenchy,
I wanted to be sure to correct/clarify my previous post, after re-reading it....
Neither Max's, nor James' NodeEditor is "Broken" as it seemed i implied....
It's just that people are making modifications to the default, Max's files, that then make the same calls incompatible with each other...
Someone could keeps saying, Make a new "Points3, Points4, Points5 file, then implement those, instead of re-writing the default Points.js file, etc....
But really there are only a couple guys that will do this type of coding.
So what's really easier for me, is to just make a nodeeditor install for max, james, kartesen etc....
I can also evaluate the developments of those guys as they go too!!! (Not that I am a huge node guy... Just passing a method out to others that may want to be able to run the nodes that others post at any given time...
I imagine at some point, it will have to get wrangled in, or it will just be left as is. I didnt get that Max was "starting a business", so it's just a free for all at the moment...
9949.26 In reply to 9949.25
Fully understandable : it's for that i preconise for each New node to send all the nodeeditor package :)
No very ecologic but avoid a lot of headaches!
9949.27
attached a version that as a limit on the thread length thus stopping it accidently running into the head.
I have set the limit at 1.5 x pitch of thread from the head.
So any input that is to big will automatically be corrected.
Wayne,
If you wanted to 3D print a Screw & nut a thread cutter node for the nut could be done with an adjustable clearance by offsetting the thread profile.
I will have a look at adding that option.
Barry
9949.28 In reply to 9949.27
Hi Barry,
Thank you! This sample 3D printed screw and nut has been sitting on my desk for many years as an inspiration for this type of project sometime or another.
I was having trouble with the nut thread as detailed here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9685.8
Pilou has a solution by rotating the nut to allow the curve intersection to offset.
Thank you,
Wayne
EDITED: 17 Jan 2021 by WAYNEHILL5202
9949.29 In reply to 9949.28
Funny material! :)
9949.30 In reply to 9949.28
Hi Wayne,
the picture shows a M16 x 2pitch example with a 0.1mm clearance which I created manually using an offset of the form.
Not sure if its this method is best option yet.
Also with the thread form being 60 degrees printing without supports may be an issue.
Anyway i will see if the manual method I used can be transferred to a node.
Barry
9949.31 In reply to 9949.30
Hi Barry,
What you are refering to is what the machining industry calls the "H Limit" or the "L Limit"....
You'll find it as a number system for taps and dies like, H1-H7 or L1-L7 etc......
They reference a tolerance value... So aerospace needs high tolerances. Home depot stuff wiggles around on each other before it's tightend...
It's basically/simply achieved by the depth of the thread cutting tool..
so to make workable nuts and bolts, you will need a "3rd object generated" which will be the tap or the die, to boolean the threads, to work with the current "M12 Bolt" etc....
I dont know enough to be able to just give you the numbers... A Machinsts Handbook can, or asking in a CNC forum also...
9949.32 In reply to 9949.31
An image to be explanatory...
If the red form was the thread, the upper and lower forms would be various H and L Limits...
9949.33 In reply to 9949.32
Hi Burr,
thanks I was thinking of offsetting the form to give a constant clearance for 3D printing.
Your method will make it easier the only thing is that to give say 0.05 clearance due to the 60 degree thread form
the former moves 0.1mm but that's no problem.
Many thanks
Barry
9949.34 In reply to 9949.33
Hi Barry,
Sure thing...
Just clarifying because we have such diversity in language in the forum....
The term of offsetting the thread form.... if we use "moi's offset command" you would get erroneous results.... but the term offset, as in "move the cutting form in and out of the cut, is how a guy actually making a nut and bolt would do it...
I am pretty sure you got that part.... just adding it in for the forum....
Always like watching your work go by.....
There is an xml file with metric thread settings for 3d printing which someone prepared in excel. (re: Fusion 360)
Notepad++ shows the text entries. There are external Class 6g, and internal Class 6H, (whatever those are).
There is also a link to Garden Hose Thread xml file contents.
9949.36 In reply to 9949.28
hi Wayne,
the attached nod file will allow you to create a screw and nut for 3D printing.
You can adjust the clearance to suit.
There are 2 thread form options 60 degree inclusive and 90 degrees.
The nut is just a cylinder but you can Isect boolean any shape you want from it.
Anyway have a play.
Barry
Size: 90.2 KB, Downloaded: 27 times, Dimensions: 600x444px
9949.37 In reply to 9949.36
Hi Barry,
Thank you! I am going to 3d print one tomorrow morning!
Wayne
9949.38 In reply to 9949.36
Hi Barry,
The screw and nut were printed together at the largest tolerance. It worked spectacular with the nut freely going up and down the screw.
The first attempt was at a lower tolerance and the nut seized to the screw. Will be looking for a good midpoint. Your program works great!
Thank you,
Wayne
9949.39 In reply to 9949.38
Hi wayne,
Your printer will have some spacing settings like a step size, pass depth etc... these will affect your tolerance ability there... so the tolerance wont be a direct correlation to a printers "tolerance"...
A step size on an angled surface, to achieve a tolerance on something that has to "slide together" will be exaggerated.....
Just a note....
9949.40 In reply to 9949.38
Hi Wayne,
I printed a 12mm dia screw x 50mm and 3 nuts x 20mm long with a 2mm pitch 90 degree form separately.
The clearances 0.15/0.2/0.25mm.
The 0.25 nut no problem.
0.2 nut required working along the screw a couple of times but fine.
The 0.15 would only go onto the screw about 12mm with a lot of working back and forth.
I think the 0.15 clearance would have worked with a shorter nut maybe its down to shrinkage.
Anyway glad it works.
Barry
EDITED: 10 Mar 2023 by BARRY-H
Show messages:  1-20  21-40  41-43
