V4 beta Sep-10-2020 available now
 1  …  22-41  42-61  62-81  82-101  102-118
restore defaults does not seem to work for Options Dimensions, arrowhead or line lengths, etc...?
When in the Dims section of Options, After hitting restore defaults button, does Current Section Only refer to the Dims section?
And Everything refer to all of the option setting tabs?
9942.63 In reply to 9942.62
Hi Brian, You should find the dimensions very easy and flexible
with presets, try this from Michael, it's very slightly edited:
Go to Options > Dimensions , create some settings for a 'preset'
and then when ready at the top of the window push “Add” to add in a new dimension property preset.
You could add in one preset that you want to use for horizontal dims and set it to have text height 12,
and then an additional one for radial dims and set it to have text height 6.
Then when you are in the horizontal dimension command, go to the command options in the upper right corner of the screen
and there is a “Preset” option there where you can tell it which preset to use. Set it to the one you added for linear dimensions.
Similarly in the DimRadius command, set it to use the preset that has the properties you want for radial dimensions.
Once you have that set up you should be able to create linear dimensions or radial dimensions and they will each start out with their own different properties.
The way the storage of the presets work is the “Default” preset is stored in your moi.ini file and so it will automatically be available in any new project. The other presets after Default are stored inside a .3dm project file so you can have different ones on a per-project basis. If you want those other presets to be available when you start up a brand new file then make a .3dm file that has them set up as you want and specify that file as the startup template under Options > General > Template file. Then when you start a new project it will go grab the presets from that file.
Stefano
9942.64 In reply to 9942.62
Hi Brian, for the reset "everything" means all sections, otherwise it will reset only the stuff in the current active section.
And yes, it doesn't do anything for the Dimensions but I will tune that up. There is another way to reset it right now, if you delete the default property preset it will remake it with default settings.
9942.65 In reply to 9942.56
Hi Mindset, yes for a single headed arrow you can use Dim > Leader and leave the text blank. When the dialog for text pops up just push "OK" without putting in any text:
9942.66 In reply to 9942.58
> Add option to dimAngle factory for not displayiing angle numbers?
You can remove the text from an angular dimension by selecting it and then click the "Details..." button in the properties panel in the upper right.
Inside "Annotation properties", there is a Text: field. By default it will read "<>" , the <> part will be where the numbers will be added.
If you remove the <> and have a blank text property then there won't be any text or numbers displayed for that dimension.
You an also add in text with the <> included where you want the number, like if you put in
Text: This angle is: <>
That would result in this kind of display:
> New question: The result of the dimAngle looks line a drawn archery bow, with the string being
> two lines. Are the two lines needed,or can there be an option to not show the two lines
At the moment there isn't any way to not show the extension lines. I can add in an option for that.
> The drawn bow seems to be one object, some type of object. It cannot be separated? Nor portions deleted?
Correct, it's a specialized object type, there isn't currently any way to separate it out into different components. It could be possible to make it respond to Edit > Separate and convert it into some lines and arcs and a text entity but that would be sometime after v4.
9942.67 In reply to 9942.61
> A quick search shows that some CAD programs use "Spline Leaders," and "Arc Leaders."
I would like to have an option for the leader to be a spline curve instead of a polyline but it won't be for version 4.
> The arc leader in Autocad had a slightly curved arrow.
Yes, that one seemed pretty weird.
> So a guess would be that dimensions represent a special kind of geometric
> object, not subject to many of MoI's commands?
Correct, they are a distinct "Annotation" object type. They have their own new area in the "Types" section of the scene browser. There are 5 different sub types of annotations currently: Linear dimension, Radial dimension, Angular dimension, Leader, and Text.
There are several commands that can work on them like Transforms, Delete, Copy, Paste. But not model construction stuff like Extrude, Revolve, etc...
Thank you Michael and Stefano, for all of the useful explanations.
Editing dims with the Details button is cool.
A very short leader arrow can be added to one end of a circular arc, to simulate an arc leader. Do not know if this is OK or not.
EDITED: 16 Sep 2020 by BEMFARMER
9942.69 In reply to 9942.68
Hi Brian, it was great spending a few hours on the dimensions tools ( annotations).
I also created a quick way to do custom 'leaders' (which I prefer to call "callouts") and will likely demo
that and a few other things on my post #9950 later . Cheers Stefano
EDITED: 16 Sep 2020 by LIGHTWAVE
9942.70 In reply to 9942.60
Thank you for responding.
> If you right click on the app and choose "Show package contents", then go into the commands folder, there should be a file there named "WaitForDialogDone.js" . Is it missing?
You're right! Everything that comes after the 'T' is gone!?!
So I will download/install it again. Thanks so much!
- Reggy
9942.71 In reply to 9942.70
Hi Reggy, you're welcome I'm glad that was it.
9942.72 In reply to 9942.50
thank you for deep explanation, as usual.
It isn't so important readibility AI format v8 by Affinity, but it is more important that MOI generate older AI format, because most of laser cut machines use just old AI format insted of new one.
Affinity reads PDF files generated by MOI without problem.
Thanks.
Mik
9942.73 In reply to 9942.13
"> Just so I am clear, this "Gaurd Rail" function is "NEW", Correct?
Correct."
That is a typo, right?
9942.74 In reply to 9942.73
Hi Pauland, see here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9942.13
I think its spelt "Guard"!
- Stefano
9942.75 In reply to 9942.74
Yes, that's why I asked the question - I haven't tried V4 yet so I wondered if there was some mis-spelling in the program.
9942.76 In reply to 9942.75
Hi pauland, no that text is not in the program itself, that's just text in a discussion here on the forum.
9942.77
The new release is looking really good, I'm loving the new dimension tools.
Apologies if this has been covered already.
Is it possible to have the new dimension objects editable by double clicking (or even shift+click or ctrl+click) them in the viewing window. Currently the only way (that I can see) to access the edit dialog box is to select the object and then click the details button over on the right toolbar.
Thanks, Dan.
9942.78 In reply to 9942.77
Hi Dan, right now I'm not sure what I'll be doing with double click, I want to keep it available until some other pieces like groups are set up.
You can set up a keyboard shortcut to open up the Details... dialog though. To do that set this on a shortcut key:
script: /* Show object properties dialog */ moi.ui.createDialog( 'ObjectPropertiesDialog.htm', 'resizeable,defaultWidth:700,defaultHeight:500' );
9942.79 In reply to 9942.78
I would urge anyone using dimensions tools to work with that shortcut and presets as well.
Presets are really flexible. You can set up simple generic ones e.g. text 6pt,8pt,10pt
By type e.g. arrow 1,2,3, by main display feature e.g. horizontal/vertical boxed text, leader dot, leader arrow.
It is almost too flexible!
I also use a shortcut on "O" to open options dialogue box. At moment there
is no link between details and presets page so I find creating presets on the fly is best done with
an options dialogue box shortcut. My post #9950 is work in progress and will cover some of this.
Hi Dan I use this one;
O = Options
moi.ui.createDialog( 'moi://ui/options.htm','resizeable,default');
(this might not be textbook, i have shortened this on purpose,new to MOI & scripts and just wanted
to see what works in shortest form possible)
I also use:
H= DimHorizontal FromObject
V= DimVertical FromObject
I'm hoping for a one click segment dimension tool in future, thats mentioned/shown here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9950.4
Shortcuts for managing 'presets' fast, here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9950.13
EDITED: 21 Sep 2020 by LIGHTWAVE
9942.80 In reply to 9942.78
Thanks Michael,
That works for me, cheers.
9942.81
< Not bad! That will be from the new parallelized loader in v4, it's able to chew on processing objects using multiple CPU cores> quote from Michael
387 MB .3dm ... 4.43 sec ! Thanks for the hard work !
EDITED: 16 Jan 2023 by PAQ
Show messages:  1  2-21  22-41  42-61  62-81  82-101  102-118
