V4 beta Sep-10-2020 available now
 1-8  9-28  29-48  49-68  69-88  …  109-118
9942.29 In reply to 9942.28
Here the 2 files...
https://moiscript.weebly.com/uploads/3/9/3/8/3938813/2scriptsmenus.zip
Don't remember to add some special names of scripts..
9942.30 In reply to 9942.29
Thanks Pilou, those seem to be ok.
Can you please go to a command prompt window and use this:
dir %appdata%\Moi\commands > output.txt
And then send me the output.txt file? It will have a listing of all the files in your appdata commands folder so I can see if there is a problem with any of the names.
9942.31 In reply to 9942.30
where must be this output.txt ?
Not more easy for me to send you the commands folder by mail? (810 Kb )
because my Windows CMD says dir is not found! :)
EDITED: 13 Sep 2020 by PILOU
9942.32 In reply to 9942.31
Hi Pilou, it can be anywhere, that command line will write it to the current directory of the command line.
Maybe try these 2 commands on the system command prompt window:
cd %appdata%\Moi\commands
dir >output.txt
The first line will set the current directory to the Moi appdata commands folder, and the second one will do the "dir" directory listing command and send its output to a text file output.txt which will be created in that same folder.
If you can then send me that then I may be able to recreate the problem over here and fix it up.
9942.33 In reply to 9942.31
That would work fine too.
9942.34 In reply to 9942.32
Don't find CD! :)
I send you the Zip of my Folder commands from the Appdata
9942.35 In reply to 9942.31
Hi Pilou, I think Michael's saying use windows command prompt to find the "hidden" %apps% moi directory and put the output text file there. If this is just a question of "pasting" a file once...
might navigate manually through windows explorer but you need turn "hidden files" off 1st...
Open File Explorer from the taskbar.
Select View > Options > Change folder and search options.
Select the View tab and, in Advanced settings, select Show hidden files, folders, and drives and OK.
9942.36 In reply to 9942.34
Hi Pilou, are you maybe putting in dir or cd into the Windows "Run" dialog? That's not the same as an actual command prompt.
To get a command prompt you would need to first run cmd.exe .
Then inside the command shell that's where you put in dir or cd. But sending the .zip file is fine.
9942.37 In reply to 9942.36
Yes I suppose that is the SHortCut for my Windows 10 (Logo Windows + R) for have the command system
but after it's a mess Windows cmd don't find your dir etc...
So I send you by mail the commands folder with pain again because Gmail don't want my zip ! :D
I have found an other way! :)
9942.38 In reply to 9942.37
Hi Pilou, it seems to be a bug in the menu code. Try updating to the attached versions, these are in %appdata%\moi\customui .
9942.39 In reply to 9942.38
Works fine now! Bravo!
9942.40
Thanks for continuously developing Moi!
Perhaps I've found a bug, If I use this script - script: /* Toggle browser pane on/off */ moi.ui.showBrowserPane = !moi.ui.showBrowserPane; or this- script: /* Toggle between opposite and inline browser modes */ moi.ui.browserPosition = (moi.ui.browserPosition == 'Inside' ? 'Opposite' : 'Inside');
and press the hotkey several times Moi freezes completely.
9942.41 In reply to 9942.38
Hi Michael and thanks for this new update.
I've seen that there are a bunch of things that didn't work properly with the update you posted, something that you already fixed (if I'm not wrong)
Could you please upload a NEW fixed update with all the corrected stuff already packed into?
In this way is much more easy for us to pick the right version without the need to scroll all the posts to find errors and fixes.
Thanks a lot.
9942.42 In reply to 9942.41
Hi Marco,
Are you talking about Scripts.menu.htm and ScriptsFull.menu.htm above?
I don't know about any bunch of things wrong with them, Pilou posted about a problem with the columns here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9942.26 and the files I posted are just for solving that problem.
Sorry no I can't - it's part of Max's CustomUI package. The main version for it is on his file archive page which belongs to him, I don't have any way to change it.
9942.43 In reply to 9942.40
Hi surferdude,
It definitely sounds like a bug, thanks for reporting it.
What operating system are you running on?
9942.44 In reply to 9942.43
I'm using Windows 10 Pro 1903 64 bit
Thanks!
9942.45 In reply to 9942.42
Hi Michael.
"Are you talking about Scripts.menu.htm and ScriptsFull.menu.htm above?"
Yes
"I don't know about any bunch of things wrong with them"
Ok
"Sorry no I can't - it's part of Max's CustomUI package."
Ok.
Thanks!
9942.46
It seems I can no longer export to pdf and have a usable template with this latest beta. When I choose Center Object it appears truncated in the upper RH corner of the page. It may be user error but I have had great success with this feature in the past.
I've included the file and pdf for you when you get a chance to look at it.
In case anyone wood carves and is curious the end project looks like so:
Best regards,
David W.
Size: 396.1 KB, Downloaded: 47 times, Dimensions: 686x793px
9942.47 In reply to 9942.46
The 3dm Exports to PDF fine for me, with Top View, and Fit to page.
Do not have a Center Object option...
9942.48 In reply to 9942.47
Hi Brian, the "Center on page" option will appear if you set Scale: "Preserve units" instead of Scale: "Fit to page".
@David - I think I broke that with some recent fiddling with PDF output as part of the work for exporting dimensions to PDF. Can you please send me an e-mail (moi@moi3d.com) and I'll send you a test build for a fix?
Thanks, - Michael
Show messages:  1-8  9-28  29-48  49-68  69-88  89-108  109-118
