Nudging value increments ?
 1-8  9-24
9940.9 In reply to 9940.1
Hi Tom,
> Does such a command / script exsit ?
No, not currently. The part that makes this kind of complicated is that incrementing by a value of 1 could have a pretty different effect in different commands. Like nudging an angle value by 1 would make a much less noticeable effect than nudging a distance by 1. Another issue is that it would be sensitive to the overall object scale as well, like if your model is 1000 units across then nudging by 1 is a small amount and if your model is 0.1 units across nudging by 1 is a large amount.
Those are some of the reasons why I haven't attempted that yet.
It is possible to input relative values in input controls though, like if an input field currently has a value of 10 in it, you can type "+1" which will give it a value of 11.
9940.10 In reply to 9940.9
The +1 tip is a nice little helper, good to know !
So French Pilou, now I will integrate your slider idea and
try it out ;-)
In fact i don't know what is this KeyStroke system! :)
Have you some video of that ?
Or a program who use it ?
Bienvenue in the Nodes World! :)
9940.12
Very simple :
Here is the script : http://kyticka.webzdarma.cz/3d/moi/#Nudge
Purpose : To move a selected object by pressing a key of your keyboard.
Lets say you have set your Snap Distance to 1mm.
When vou press "arrow up" the selected object will move up in increments of 1mm.
When vou press "arrow down" the selected object will move down in increments of 1mm.
I find it specially helpful to move selected curve points.
EDITED: 9 Sep 2020 by SIRTOM
9940.13 In reply to 9940.12
Yes I know this one, but you said it's for Move and not for Extrude, Offset... :)
You can of course use also Elephant for move something! :)
9940.14 In reply to 9940.13
Exactly, it is for moving objects.
I hoped it could be also used for Extrude, etc, but as Michael
explained, unfortunately not.
With numeric field active in extrudt, I used Tab +1, enter, for example. But it is a one time increment. ?
9940.16 In reply to 9940.15
The way Extrude works is that the command finishes when you type in a numeric value, like if you select a curve, run Extrude then type 5 and push enter it's all finished. Using a relative value does the same thing.
If you like you can modify it so it doesn't do that. To do that comment out line #109 in Extrude.js, marked with <<<<< here:
	while ( 1 )
		if ( !pointpicker.waitForEvent() )
			return;
		if ( pointpicker.event == 'done' )
			break;
		else if ( pointpicker.event == 'distanceinput' )
			factory.setInput( 2, moi.ui.commandUI.distanceinput.value );
			factory.update();
			//break; <<<<<<
		else if ( pointpicker.event == 'setdirection' )
And also comment out line #69:
	moi.ui.beginUIUpdate();
	moi.ui.hideUI( 'SelectionPrompt' );
	//moi.ui.hideUI( 'done' ); <<<<<<
	moi.ui.showUI( 'ExtrusionPrompt' );
	moi.ui.showUI( 'ExtrusionOptions' );
But if you do that then an extra action is needed to end the command. If you want to extrude by a value of 5 you now would need to type 5 <enter> to set the distance field and then an addition <enter> (or click "Done") to finish the command.
9940.17
You can select the control points and nudge them around.
EDITED: 17 Jan 2021 by WAYNEHILL5202
9940.18 In reply to 9940.16
Thank you Michael.
I'm content with the default Extrude configuration.
9940.19 In reply to 9940.17
You are right. But if I want to extrude a selected surface segment there are no pointsto be nudged, unfortunately ...
9940.20 In reply to 9940.17
Hi Wayne, found that "post"...
Decided for next few weeks to work with a totally standard
version of moi v4 beta. No custom ui, no .ini mods,
just maybe some shortcuts.
I think your draw/edit menu set up is the best I've seen.
Is there a way to get that without doing coding?
Maybe your menu could become a 'standard' ?!
I dont like clicking into menu tabs if not required
and think you've nailed it (simply).
Stefano
9940.21 In reply to 9940.20
Hi Stefano,
The MiniSidepane.js is Max's program located here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=8064.8
Wayne
9940.22 In reply to 9940.21
Many thanks Wayne. Will definitely try..
9940.23 In reply to 9940.22
The second line is commented out for use with Moi V4.
9940.24 In reply to 9940.23
There's also SeparateSidePanePalettes.js which you can get here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9439.3
That one keeps all the content, I think the other one removes some things.
Show messages:  1-8  9-24
