Booleans and Shelled solids
All  1-6  7-16
If it could help...
I do a curve.
Then I revolve it with or without cap. With cap I delete it to test.
When I do my shell, the "in" surface and "out" surface is one and only 1 surface.
I can't separate them.
So it's "normal" you could not cut and find distinct edges.
If the shell is done "fliped" we don't have this problem.
If the shell is done with centerline, we can't have something done.
9939.8 In reply to 9939.7
Yes totally agreed with this...that was exactly that i made! :)
Don't remember there was this sort of problem with the Revolve function + Shell...
Found something strange... If it can help to analyze the problem...
If I revolve the curve.
Save, exit, reopen and shell the surface, you don't have the problem...
9939.10 In reply to 9939.9
Yes seems there is something inside the Revolve and/or Shell and /or Booleans functions! :)
Maybe one explanation ?
EDITED: 10 Sep 2020 by PILOU
9939.11 In reply to 9939.10
Something that collapses down to a point can cause problems for shelling and offsetting, particularly towards the inside and if the surface is not smooth at the point. The offset surface will get bunched up with pieces crossing over themselves:
For that particular kind of shape it can be better to do a curve offset and prepare the curve outline so that the result of the revolve has the thickness in it just with the revolve:
9939.12 In reply to 9939.10
Offsets of things that are smooth to each other will have the individual offset pieces naturally touch each other:
Offsets of things that are not smooth results in offset pieces that do not touch each other, they either cross each other or have a gap that needs to be filled in:
I thought same but how explain this :
So I think the shell on the revolving has a problem.
Perhaps a rest of history ?
Michael, could you test and see if this experience is same for you ?
Left a curve is revolved then shelled.
Right a curve has been revolved then saved, exit of Moi, reenter Moi reopen file and shelled the surface.
See the center of inside render indicating the problem.
EDITED: 10 Sep 2020 by PHIRO
Size: 317.4 KB, Downloaded: 23 times, Dimensions: 697x454px
During shelling, we think the operation has been ok but in fact, shell has done a curve (on previous picture selected), but didn't use it to construct the internal surface.
It constructs a single surface which is unique, intern and extern.
9939.15 In reply to 9939.14
Hi Phiro, the weird piece that looks like a curve is a surface but with a messed up trimming boundary on it which prevents it from getting a proper shaded display like surfaces normally have. If you select it and use Edit > Show pts you can see the surface control points and if you select its 2 edges and use Delete to untrim it that will recover the surface.
Thx for the explanations!
A little more clear now! :)
And no need to make a plane a simple line is sufficient ;)
Show messages: All  1-6  7-16
