Booleans and Shelled solids
All  1-12  13-16
I thought same but how explain this :
If I revolve the curve.
Save, exit, reopen and shell the surface, you don't have the problem...
So I think the shell on the revolving has a problem.
Perhaps a rest of history ?
Michael, could you test and see if this experience is same for you ?
Left a curve is revolved then shelled.
Right a curve has been revolved then saved, exit of Moi, reenter Moi reopen file and shelled the surface.
See the center of inside render indicating the problem.
EDITED: 10 Sep 2020 by PHIRO
Size: 317.4 KB, Downloaded: 23 times, Dimensions: 697x454px
During shelling, we think the operation has been ok but in fact, shell has done a curve (on previous picture selected), but didn't use it to construct the internal surface.
It constructs a single surface which is unique, intern and extern.
9939.15 In reply to 9939.14
Hi Phiro, the weird piece that looks like a curve is a surface but with a messed up trimming boundary on it which prevents it from getting a proper shaded display like surfaces normally have. If you select it and use Edit > Show pts you can see the surface control points and if you select its 2 edges and use Delete to untrim it that will recover the surface.
Thx for the explanations!
A little more clear now! :)
And no need to make a plane a simple line is sufficient ;)
EDITED: 10 Sep 2020 by PILOU
Show messages: All  1-12  13-16
