How to do that shape correctly
All  1-2  3-4
9933.3 In reply to 9933.1
Hi mdesign, to get a sweep without errors the profile curve can't extend a distance further than the radius of curvature of the bend.
For your case here that means the length away from the rail can't be larger than about this much:
One possibility though is to do the sweep that folds over itself, then use Edit > Trim with the "Isocurve" option to cut out the messy section:
Then you can put in a Blend there:
9933.4 In reply to 9933.3
Brilliant. Thanks for help. So I needed to use that bad geometry to create a good one. Wise :)
Show messages: All  1-2  3-4
