multiple undo / redo
All  1-4  5-6
9931.5 In reply to 9931.4
Hi Michael;
Control copied 30 shapes onto drawing and then did "undo" (control z) back to zero objects;ALL GOOD.
I think the "redo" button missed me before and was trying to 'redo' by pressing control+shift+z
then thinking 'nothing happening'. So....re-assigned "re-do" in options/shortcuts from control Y
to what i'm used to: (control + shift +z).
All perfect now cheers!
PS. Custom UI now installed. Found the instructions required bit of concentration / trial and error.
Lighting options not working but im fine with that till another day....
9931.6 In reply to 9931.5
Hi Stefano, that's great that is sorted out!
For the lighting options, that is looking for a chunk of information saved into moi.ini by another plug-in, this one here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5222.48
If you run that other plug-in it will set up the information that CustomUI is looking for and then the lighting options should work after that.
Show messages: All  1-4  5-6
